Can I bypass or run without the throttle body heater valve?
Old Dec 6, 2005 | 05:32 PM
nissaninahondaworld's Avatar
Default Can I bypass or run without the throttle body heater valve?
The thing I am talking about is the little valve on the bottom of the throttle body, that runs water through it to heat it up. Can I remove this and just make a block off plate instead of leaving it's ugly face there? Thanks!
Old Dec 6, 2005 | 05:34 PM
platinum00's Avatar
Default Re: Can I bypass or run without the throttle body heater valve? (nissaninahondaworld)
Yes, it you live somewhere that is not below 20 or so
platinum.
Old Dec 6, 2005 | 05:36 PM
Default Re: Can I bypass or run without the throttle body heater valve? (platinum00)
What about if I don't drive it in the winter?
Old Dec 6, 2005 | 05:37 PM
platinum00's Avatar
then it woudnt be below 20
platinum
Old Dec 6, 2005 | 06:27 PM
Bimmerman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nissaninahondaworld &raquo;</TD></TR><TR><TD CLASS="quote">The thing I am talking about is the little valve on the bottom of the throttle body, that runs water through it to heat it up. Can I remove this and just make a block off plate instead of leaving it's ugly face there? Thanks!</TD></TR></TABLE>
I have done this on several Civics, but it nevers gets really cold where I live.
joenobodyyet
Honda Civic (2006 - 2015)
Nov 1, 2018 12:47 PM
jofu
Honda CR-V & Element
Apr 20, 2018 06:18 AM
DarkDragon
Nov 17, 2005 06:34 PM
