Suspension & Brakes Theory, alignment, spring rates....
Rear springs not being compressed
Old Dec 6, 2005 | 04:17 PM
mike9571's Avatar
Default Rear springs not being compressed
A buddy of mine just installed 2in lowerings springs on his DA. The rear springs didnt get compressed like the front when everthing was tight, but still in the air. What is the deal with this? Is this normal?...thanks
Old Dec 6, 2005 | 04:54 PM
_BEN_'s Avatar
Default Re: Rear springs not being compressed (mike9571)
Does it look like a top fuel dragster? (slammed in the front / jacked up in the rear)
If so you probably put the rear springs in the front and the fronts in the rear.
Old Dec 6, 2005 | 04:57 PM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">A buddy of mine just installed 2in lowerings springs on his DA. The rear springs didnt get compressed like the front when everthing was tight, but still in the air. What is the deal with this? Is this normal?...thanks</TD></TR></TABLE>
Ok thats hard to understand. He said when the front was put back together and tightend up (but still on jacks) the springs were compressed at not loose at all. But when the rear was assembled and tightend up (but still on jacks) the springs were compressed at all. obvioulsy when the car was put on the ground they were compressed....whats the deal???
Old Dec 6, 2005 | 04:59 PM
mike9571's Avatar
no not at all....i looked at the springs and they have R for rear and F for front. The car looks fine, rides fine.
Old Dec 6, 2005 | 05:26 PM
mike9571's Avatar
anyone???
Old Dec 6, 2005 | 06:00 PM
mike9571's Avatar
bump
Old Dec 6, 2005 | 06:08 PM
Tyson's Avatar
its fine.
what springs?
anyway, its fine.
Old Dec 6, 2005 | 06:12 PM
mike9571's Avatar
Default Re: Rear springs not being compressed (Tyson)
H&R race...ok cool thanks
Old Dec 6, 2005 | 06:16 PM
Tyson's Avatar
H&R race are low. its typical.
its not fine that youre that low. but thats somewhat subjective.
Old Dec 6, 2005 | 06:19 PM
mike9571's Avatar
What do you mean its not ok that its that low. Its still about 3-4 inches till the pinchwelds touch the ground
Old Dec 6, 2005 | 06:37 PM
Tyson's Avatar
hmm.. nevermind.
(ignorance is bliss.)
Old Dec 6, 2005 | 06:46 PM
mike9571's Avatar
so it is normal for the springs not to be comprssed until on the ground???
Old Dec 6, 2005 | 07:09 PM
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">so it is normal for the springs not to be comprssed until on the ground???</TD></TR></TABLE>
What you are experiencing is not uncommon when you use a spring that is set up to lower the car quite a bit and often has a relatively short free length and aybe a pretty big rate increase over stock. If the spring falls out of the perch when you jack it up and the wheels are off the ground, just make sure that when you lower it back down that the top coils go back and seat in the right place.
Rarely when you are driving the car will the wheels come off the ground long enough to unseat the springs. If so, you have a bigger problem than unseated springs. Maybe not the most preferred situation but no uncommon with short slowering springs.
Old Dec 6, 2005 | 07:31 PM
mike9571's Avatar
Default Re: Rear springs not being compressed (CRX Lee)
Thanks for your help!
AllmotorGSReg
Apr 23, 2009 05:57 AM
apm
Suspension & Brakes
23
Apr 11, 2006 09:22 PM
DRKSol
Suspension & Brakes
Jun 7, 2005 12:47 PM
Solracer
22
Nov 3, 2004 02:47 PM
