Tag Screw
Old Dec 6, 2005 | 01:10 PM
ruah_23's Avatar
Default Tag Screw
Ok I just bought this car awhile ago, and I have to change the tag. The problem is that the screw that hold one of the tag is rusted to the bone, and there's now way to unscrew it. I tried spraying it with 4wd oil spray,but it's still tight. Do you guys have any suggestions??
Old Dec 6, 2005 | 01:12 PM
Kendall's Avatar
Two words: "Impact Screwdriver"
Old Dec 6, 2005 | 01:20 PM
littleredcivic's Avatar
you can try penetrating lube (not the type for the bedroom) or automatic transmission fluid. if not, use what kendall suggested, impact.
Old Dec 6, 2005 | 01:23 PM
nocturnaldragon's Avatar
Default Re: (littleredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic &raquo;</TD></TR><TR><TD CLASS="quote">you can try penetrating lube (not the type for the bedroom) or automatic transmission fluid. if not, use what kendall suggested, impact.</TD></TR></TABLE>
hahahaha
Or you can drill and tap if all else fails, I would get some stainless to put in there instead. thats what I did after I had to drill mine out. looks better and its a hex key to get them out not something your average guy will have with them if there trying to steal your plates. (Common around here)
Old Dec 6, 2005 | 01:29 PM
ruah_23's Avatar
Default Re: (Kendall)
Do u know whether I can rent that at home depot or something?
Old Dec 6, 2005 | 01:31 PM
Kendall's Avatar
Default Re: (ruah_23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruah_23 &raquo;</TD></TR><TR><TD CLASS="quote">Do u know whether I can rent that at home depot or something?</TD></TR></TABLE>
Every Autozone in America has cheap ones they sell for around 10 bucks or so. I personally have a Mac Tools impact screwdriver and love the hell out of it.
Old Dec 7, 2005 | 08:57 PM
is this the screw that hold the plate to the bumper? trunk? lower front plate mount?
Old Dec 7, 2005 | 09:57 PM
civic_driver's Avatar
cut it with a see-saw (or whatever that tool is called) from behind the plate... I fixed mine by using those locking nuts that lock into **** the more you tighten it. So I put that in the back and then used an M5 hex head screw with a washer to hold it in. It holds it in so well it's too good. The locking nut grabs the bumper harder as you tighten it. I had those nuts/screws left from when I built my sub box.
honda-guy72
32
Sep 21, 2008 09:54 PM
1ceHacka
Aug 5, 2006 03:11 PM
EG93si
36
Jan 17, 2006 11:44 AM
1bad16v
Mar 7, 2005 07:32 AM
.jacob
31
Nov 12, 2003 05:00 PM
