Tag Screw
Tag Screw
Ok I just bought this car awhile ago, and I have to change the tag. The problem is that the screw that hold one of the tag is rusted to the bone, and there's now way to unscrew it. I tried spraying it with 4wd oil spray,but it's still tight. Do you guys have any suggestions??
Re: (littleredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic »</TD></TR><TR><TD CLASS="quote">you can try penetrating lube (not the type for the bedroom) or automatic transmission fluid. if not, use what kendall suggested, impact.</TD></TR></TABLE>
hahahaha
Or you can drill and tap if all else fails, I would get some stainless to put in there instead. thats what I did after I had to drill mine out. looks better and its a hex key to get them out not something your average guy will have with them if there trying to steal your plates. (Common around here)
hahahaha
Re: (ruah_23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruah_23 »</TD></TR><TR><TD CLASS="quote">Do u know whether I can rent that at home depot or something?</TD></TR></TABLE>
Every Autozone in America has cheap ones they sell for around 10 bucks or so. I personally have a Mac Tools impact screwdriver and love the hell out of it.
cut it with a see-saw (or whatever that tool is called) from behind the plate... I fixed mine by using those locking nuts that lock into **** the more you tighten it. So I put that in the back and then used an M5 hex head screw with a washer to hold it in. It holds it in so well it's too good. The locking nut grabs the bumper harder as you tighten it. I had those nuts/screws left from when I built my sub box.
.jacob
31
11-12-2003 05:00 PM
