backfire and loss of gas mileage
Old Dec 6, 2005 | 12:51 PM
Cypher0117's Avatar
Default backfire and loss of gas mileage
like the title says. Over the past two gas tanks my gas mileage have decreased about 10mpg. And has also started backfireing. Im guessing its running rich. could cold weather have anything to do with it? If it is running rich how do i tell for sure and how would i go about fixing that. I think the timming is good because i've never played w/ it.
Old Dec 6, 2005 | 12:57 PM
duggy's Avatar
Have you ever tried to do a tune up? New o2 sensor and all that.
Old Dec 6, 2005 | 01:21 PM
Cypher0117's Avatar
Default Re: (duggy)
i replaced my plugs less than 8k ago and my o2 sensor was replace about 3k ago. spark wires were replaced w/ plugs and also air filter. The only thing i didn't touch was the distributor. any way to test my distributor? any other sensors to check?
Old Dec 6, 2005 | 04:48 PM
SOHCkiller's Avatar
Default Re: backfire and loss of gas mileage (Cypher0117)
I would check your fuel pressure regulator. Its easy to do. when the engine is running just pull the vacuum line off the top. If it sprays fuel its bad. If it doesnt its good. I would suggest some kind of fuel injection and throttle body cleaner. I used sea-foam. I smokes really bad for the first few minutes but my rev was a lot smoother amd it gave me better gas mileage also.
Old Dec 6, 2005 | 04:50 PM
anony95ex's Avatar
Any loss of power as well? High idling?
If it's idling high all the time, the problem may be a bad coolant temp sensor. It'll richen the mixture to warm the engine up, but if it fails and always thinks the engine's cold, it's gonna dump fuel.
Another possibility is a timing jump, if the belt and tensioner haven't been done recently...
Old Dec 6, 2005 | 04:54 PM
Cypher0117's Avatar
Default Re: backfire and loss of gas mileage (anony95ex)
it does feel like it has lost high end power. and sometimes bogs down (assuming because of too much fuel)....to check the timming i have to take the valve cover off to get at the cam gear right?
Old Dec 6, 2005 | 06:38 PM
anony95ex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cypher0117 &raquo;</TD></TR><TR><TD CLASS="quote">it does feel like it has lost high end power. and sometimes bogs down (assuming because of too much fuel)....to check the timming i have to take the valve cover off to get at the cam gear right?</TD></TR></TABLE>
No, just pull the cap off the distributor. When the crank is at TDC, the rotor should squarely line up with the #1 pin on the distributor cap.
Old Dec 7, 2005 | 12:55 PM
Cypher0117's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anony95ex &raquo;</TD></TR><TR><TD CLASS="quote">No, just pull the cap off the distributor. When the crank is at TDC, the rotor should squarely line up with the #1 pin on the distributor cap.</TD></TR></TABLE>
and if its not then i need a new distributor? how do i know if the cap is good?
Old Dec 14, 2005 | 12:54 PM
CivicVX94's Avatar
how do you put the crank at TDC?
Sorry for the newb question but I've always wondered that
Old Dec 14, 2005 | 02:18 PM
SOHCD16y8's Avatar
There is a mark on the crank pully that u align with the line on the cover
Old Oct 14, 2006 | 04:56 PM
standinghollow's Avatar
Default Re: (SOHCD16y8)
preludepower
Oct 6, 2009 08:24 PM
Wannabe JDM
Feb 9, 2006 04:19 PM
SalmanzCivic
26
Jan 7, 2005 01:02 PM
jman
Oct 29, 2002 03:56 PM
