Battery Keeps Dying
Old Dec 6, 2005 | 11:02 AM
fanta!'s Avatar
Default Battery Keeps Dying
when i first replaced my battery, it had been a while so i just replaced it to be safe. after 3 months of having the new battery it just went dead on me so i had warranty on it so i just got a new one. its been a month since ive had the new one and its dead again. alternator?
Old Dec 6, 2005 | 11:16 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Battery Keeps Dying (fanta!)
Most likely alternator...
Old Dec 6, 2005 | 11:25 AM
fanta!'s Avatar
Default Re: Battery Keeps Dying (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Most likely alternator...</TD></TR></TABLE>
if thats not it, what else could it be?
Old Dec 6, 2005 | 11:39 AM
JimmyAtlantis's Avatar
How many places did you post this? Christ!
Old Dec 6, 2005 | 12:23 PM
VTAC-KAT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fanta! &raquo;</TD></TR><TR><TD CLASS="quote">if thats not it, what else could it be?</TD></TR></TABLE>
it could be an electrical drain in the system.
First I would test the altenator with a multimeter and make sure it's putting out good voltage (14.4v i believe).
Old Dec 6, 2005 | 12:25 PM
VTcivicHB's Avatar
Or even an easier way is to disconnect the battery while the car is running, if the alternator is good the car will keep running and if the car dies, Alternator!
Old Dec 6, 2005 | 12:30 PM
pdiggitydogg's Avatar
I have the same problem
Alternator puts out 14.4 but keep ending up with a dead battery, even if I drive it a day before and do not arm the alarm system
Old Dec 6, 2005 | 12:48 PM
Default Re: (pdiggitydogg)
Try cleaning all of the connections. It worked for me once. Saved me the price of an alternator.
Old Dec 6, 2005 | 01:00 PM
yeah, I clean them every time it dies and I recharge it
Im on my third battery since june
(strangely, I dont have the issue with the optima, but do with the duralasts)
Old Dec 6, 2005 | 01:32 PM
flood's Avatar
if you check it with a multi-meter it can be misleading as the ECU controls the charging system.
If you want I have a PDF that someone sent me for trouble shooting honda charging systems.
Stupid 5 wire ecu controlled charging system!
"By turning off the alternator the computer reduces the load on the engine and thus saves fuel and increases power output when needed. "
Old Dec 6, 2005 | 02:56 PM
Id like that pdf, please
pmbritto@oakland.edu
Old Dec 6, 2005 | 06:48 PM
flood's Avatar
When I get to work tomorrow AM I will send it to you. I am at home on dialup
Old Dec 7, 2005 | 05:54 AM
fanta!'s Avatar
Default Re: (JimmyAtlantis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimmyAtlantis &raquo;</TD></TR><TR><TD CLASS="quote">Try cleaning all of the connections. It worked for me once. Saved me the price of an alternator.</TD></TR></TABLE>
connections are clean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">yeah, I clean them every time it dies and I recharge it
(strangely, I dont have the issue with the optima, but do with the duralasts)</TD></TR></TABLE>
damnit, its a duralast battery. did your duralast just always go out quick on you or what was the deal?
Old Dec 7, 2005 | 12:18 PM
postman's Avatar
you probably have a parasidic draw. something in your car is drawing current when key is off that shouldnt be. way to test hook amp meter in series with neg. batt cable. if value is high. then you have a bad draw. if so leave meter hooked up and begin to pull fuses until value drops. that will let you know what circuit it is in.
ps. you must do this test while nothing in car is on no lights, cant open any doors.
Old Dec 7, 2005 | 12:29 PM
Carbonciv's Avatar
jetwinmx@Hotmail.com, id like the .pdf file too if thats not too much trouble.
Old Dec 8, 2005 | 07:13 AM
fanta!'s Avatar
Default Re: Battery Keeps Dying (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">you probably have a parasidic draw. something in your car is drawing current when key is off that shouldnt be. way to test hook amp meter in series with neg. batt cable. if value is high. then you have a bad draw. if so leave meter hooked up and begin to pull fuses until value drops. that will let you know what circuit it is in.
ps. you must do this test while nothing in car is on no lights, cant open any doors.</TD></TR></TABLE>
ill try this
Old Dec 8, 2005 | 11:46 AM
pff if you figure this out, let me know so I can tell like 3 other guys how to fix it....and a grandmother
Old Dec 8, 2005 | 11:50 AM
96CivicBoostCoupe's Avatar
sounds like you have a parasitic draw some where in a circuit in the car. Somthing besides the ecu is drawing current when the car is off
Old Dec 8, 2005 | 11:52 AM
Im really not so sure of that. Lately, civics of similar generations are all having the same problem at the same time...all for apparently no reason....its an epidemic
mycivicswaylow53
21
Nov 8, 2007 08:50 PM
crxma22
Honda Motorcycles
15
Dec 9, 2006 12:53 PM
westcoastEJ1
May 8, 2006 11:16 AM
95ejjj
Jan 8, 2006 05:44 PM
fanta!
Dec 7, 2005 10:52 AM
