hybrid d series head stud question
Old Dec 6, 2005 | 08:36 AM
spun Vtec's Avatar
Default hybrid d series head stud question
im buying a set of arp studs for my newest build
what detirmins what head stud you should use? the head or the block?
expl. im useing a d16a block and d16z head.
should i use headstuds for the a6 or the z6
my guess would be use the studs to match the head but thats just my guess.
tia
spun
Old Dec 6, 2005 | 08:41 AM
dr_latino999's Avatar
Default Re: hybrid d series head stud question (spun Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">im buying a set of arp studs for my newest build
tia
spun</TD></TR></TABLE> The headstuds for the Z6 and the A6 are the same part number, so you will want to go with the ones for the Z6. Normally though you go by the block you are using -
D16A6 --&gt; D16Z6 Studs
D16Z6 --&gt; D16Z6 Studs
D16Y8 --&gt; D16Y8 Studs
D16Z6 w Y8 Head --&gt; Gets interesting
D16A6 w Y8 Head --&gt; Still Interesting
D16Y8 w Z6 Head --&gt; Have you noticed the Y series makes everything damn difficult?
Old Dec 6, 2005 | 10:42 AM
spun Vtec's Avatar
Default Re: hybrid d series head stud question (dr_latino999)
you are sure?
Old Dec 6, 2005 | 10:56 AM
CptMidway's Avatar
I did a D15b2 / y8 swap and I used the y8 studs, but had to order 2 shorter studs from ARP.
Old Dec 6, 2005 | 11:52 AM
spun Vtec's Avatar
i need somone to comfirm what headstuds to use for a6 with z6 head please.
tia
spun
Old Dec 6, 2005 | 12:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">i need somone to comfirm what headstuds to use for a6 with z6 head please.
tia
spun</TD></TR></TABLE> It is the Z6 studs, why do I know this, because I used Z6 studs on a straight A6, Z6 studs on a straight Z6, and Z6 studs on an A6/Z6 combo
Old Dec 6, 2005 | 01:11 PM
spun Vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> It is the Z6 studs, why do I know this, because I used Z6 studs on a straight A6, Z6 studs on a straight Z6, and Z6 studs on an A6/Z6 combo </TD></TR></TABLE>
right on thank you
dafirecracker
14
Jan 29, 2009 07:13 PM
EF9ZC
Mar 21, 2006 11:49 AM
JDMKid71
Feb 13, 2006 07:05 PM
Screaming
Feb 8, 2006 12:28 PM
Jizzmaster Zero
Sep 6, 2005 10:47 AM
