Turbo???
Old Dec 6, 2005 | 08:13 AM
Jdm...'s Avatar
Default Turbo???
Whats the best Turbo on the Market. Is the H.K.S. intercooler pipes very thin, like the Greddy one? Which intercooler is bigger? Whats the max Boost on stock vs rebuilt bottom block? Whats the best emanagement, and WHY? Need some info and ideas.
Old Dec 6, 2005 | 08:24 AM
NJslvrtypes's Avatar
Default Re: Turbo??? (Jdm K20)
Oh, I have plenty of ideas.
Here comes the lecture. What are your goals as well as price range?
-Hondata K-Pro exceeds every engine management out there, by far.
- Stock bottom ends have been pushed to over 500 hp. As far as reliability, I would keep it under 350.
- Best turbo kit on the market is Full Race. For the price SCI would be second.
Full Race has an equal lenth manifold and unbelievable quality.
Answer my first questiona and I will keep going.
Old Dec 6, 2005 | 12:01 PM
Jdm...'s Avatar
Default Re: Turbo??? (NJslvrtypes)
I'm interested in 20 psi, and rebuilt bottom block.
Old Dec 6, 2005 | 04:02 PM
Well if your interested in 20+ psi your going to need a lot to say the least. Here goes:
- Full Race or SCI as recommended before
- GE or Darton sleeves
- Cunningham, Pauter, Carillo, or Manley rods
- Wiseco 9:1 pistons or Custom JE pistons
- Stock headgasket, main bearings, thrust washers, and rod bearings
- 6 Puck or Dual Disc Clutch such as ACT or Clutchmasters
- ARP headstuds
- Fuel Return Line
- Walbro Fuel Pump and Aeromotive Rising Rate Fuel Pressure Regulator
Now you are setup for 500+ hp
Old Dec 6, 2005 | 06:34 PM
Jdm...'s Avatar
Cool. Thanx for the info. What do you have for emanagement?
Old Dec 6, 2005 | 06:37 PM
i shiton u's Avatar
k pro > all
stock bottom end 320 whp, i'd be scared to push more
~10 psi daily driven
Old Dec 6, 2005 | 06:59 PM
Yup kpro definately owns all.
Also take a look at the vendors and get your parts from NoLimitMotorsports. I just picked up my Eagle/Wiseco combo for 750 shipped. They are here on the boards and they are definately the cheapest around.
Old Dec 7, 2005 | 08:25 AM
ace0fspades's Avatar
hey isn't it true that if you have a stock block that you shouldn't take a turbo above 6psi?
Old Dec 7, 2005 | 12:35 PM
PostMASTER-S27's Avatar
Default Re: Turbo??? (i shiton u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i shiton u &raquo;</TD></TR><TR><TD CLASS="quote">k pro &gt; all</TD></TR></TABLE>I was wondering about that......Is K-pro really the best for turbo tuning? i was thinking of going with HKS F-con V-pro or when it comes out Apexi Power FC. I'm going to be run the Full Race Stage 1GT with upgrade to a GT2871R on my RSX-S, with just the stock block for now. What do you think my WHP?
Old Dec 8, 2005 | 12:04 PM
Default Re: Turbo??? (PostMASTER-S27)
Got a link for HKS F-Con so we can compare.
Also, If I remember correctly only HKS dealers can program or tune their ECU's. Which is one of the main reasons K-Pro dominates
Old Dec 10, 2005 | 02:49 PM
02ep3's Avatar
Default Re: Turbo??? (ace0fspades)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ace0fspades &raquo;</TD></TR><TR><TD CLASS="quote">hey isn't it true that if you have a stock block that you shouldn't take a turbo above 6psi?</TD></TR></TABLE>
Its hard to judge psi....if you have a tiny lil turbo, you could get a higher boost, if you have a big mamma jamma turbo, the lbs could be lower
Old Dec 10, 2005 | 07:17 PM
Default Re: Turbo??? (02ep3)
oh okay, I wasn't thinking of the sizes . I guess that would make sence though.
Old Dec 14, 2005 | 07:34 PM
Jdm...'s Avatar
What is the biggest turbo, that will fit into the Rsx? Much hp 62-1 ballbearing turbo produce?
jne
Jan 31, 2010 06:04 PM
qwert12
May 24, 2007 05:00 PM
ccivic
May 23, 2004 11:19 PM
JunIntegra
Aug 8, 2003 03:32 AM
Ragezero76
Jun 10, 2002 07:42 PM
