210k miles stuff to check
after some searching ive kinda come up with a list of things to check/do since i have 210k miles on my beater. add things to the list to help me out or lemme know if these are some good things to check on.
timing check
timing belt inspection
replace MTF fluid
replace clutch fluid.
flush coolant system
valve adjustment
new fuel filter
new spark plugs
new wires/cap/rotor
new valve cover gasket (when i remove to do valve adjustment)
new oil pan/oil pan gasket (since i hit a brain bucket and dented mine/caused small leak)
how much you guys think this will run me? and what do you think sould come as priority on this list.
timing check
replace MTF fluid
valve adjustment
new fuel filter
new spark plugs
new wires/cap/rotor
B2FiNiTY
Jul 19, 2003 12:37 PM
