97' DX coupe b16 swap clutch line.
Old Dec 6, 2005 | 12:27 AM
Ax3l's Avatar
Default 97' DX coupe b16 swap clutch line.
Hey,
(I searched too, but it's all about h22 lines and ss lines.)
got any ideas on what to do with the clutch lines when swapping a b16a2 into my 97 dx coupe?
Looks like my clutch hard-line goes over my tranny in the d-series, and in the del sol wreck (where my b16 is resting) it looks like it's going along the frame rail on the passenger side.
So what do i do? Swap the hard-lines and all that from the sol' over in my civic, or will the lines allready in my car work with the new engine/tranny?
Got any thoughts on this?
-Thanks.
Old Dec 6, 2005 | 10:23 PM
Ax3l's Avatar
Default Re: 97' DX coupe b16 swap clutch line. (Ax3l)
The bump.
Should be an easy answer for this.
Old Dec 7, 2005 | 12:35 AM
Timmay's Avatar
use your stock line and slave cylinder from the car, it un-bolts off the D-tranny and works just fine on the B
Old Dec 7, 2005 | 01:03 AM
kyden's Avatar
use a clutch line from a 99-00 si.
Old Dec 7, 2005 | 06:37 AM
Timmay's Avatar
Default Re: 97' DX coupe b16 swap clutch line. (kyden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyden &raquo;</TD></TR><TR><TD CLASS="quote">use a clutch line from a 99-00 si. </TD></TR></TABLE>
why spend the money when the stock one works fine
Old Dec 7, 2005 | 09:00 AM
civichbcx's Avatar
Default Re: 97' DX coupe b16 swap clutch line. (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">use your stock line and slave cylinder from the car, it un-bolts off the D-tranny and works just fine on the B</TD></TR></TABLE>
I've often wondered this too....Good Info.
Old Dec 7, 2005 | 09:12 AM
Timmay's Avatar
Default Re: 97' DX coupe b16 swap clutch line. (civichbcx)
i just did a gsr swap in a 96 dx, i used the stock line and slave cylinder
eddie422
May 10, 2011 05:32 PM
CD7project
Apr 29, 2011 06:26 PM
DCStreetHtch
Sep 6, 2003 01:09 PM
