Exhaust valve seals VS. intake valve seals.
Old Dec 5, 2005 | 05:55 PM
Toadfart's Avatar
Default Exhaust valve seals VS. intake valve seals.
Do the exhaust and intake valve seals differ? I know they have different color springs, but I wanna know if the exhaust ones will work on the intake side and vice versa. Apparantly the brown top ones are intake and green top ones are exhaust, but after I installed a few of them, I realized that I had both green and brown top ones with both black and white springs.
I know that black springs=exhaust and white springs=intake, but do they really differ?
Old Dec 5, 2005 | 11:45 PM
Toadfart's Avatar
Default Re: Exhaust valve seals VS. intake valve seals. (Toadfart)
Nobody?
Old Feb 15, 2006 | 09:01 PM
bks84's Avatar
Loved
a little late, but they are different part numbers on acuraautomotiveparts.org
Old Feb 15, 2006 | 09:58 PM
Toadfart's Avatar
Default Re: (4sd4dr)
thanks. I was able to get the right ones.
Old Feb 15, 2006 | 10:49 PM
MAX_CFM's Avatar
Default Re: (Toadfart)
The ex seal is Viton good for hi temps ..
Old Feb 16, 2006 | 10:23 AM
Toadfart's Avatar
Default Re: (MAX_CFM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM &raquo;</TD></TR><TR><TD CLASS="quote">The ex seal is Viton good for hi temps .. </TD></TR></TABLE>
Would the exhaust seals work on the intake side?
Old Feb 16, 2006 | 10:40 AM
wildoutwhitegsr's Avatar
I don't think so.
The exhaust will work on the intake side, but not the other way around.
The stem of the intake valve is thicker than the exhaust valve.
So if you put a intake valve seal on the exhaust side, it will leak over time.
Check for yourself in the 94 Helms. Page 129 of 1413 in acrobat or 6-68 if you bought the manual.
You might be able to get away with it, but why risk it?
Old Feb 16, 2006 | 12:04 PM
VtecKiDD's Avatar
Default Re: (wildoutwhitegsr)
i run ferrea seals in mine, nopi.com sells them for 30$
Old Feb 16, 2006 | 02:38 PM
bks84's Avatar
Loved
Default Re: (VtecKiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">i run ferrea seals in mine, nopi.com sells them for 30$</TD></TR></TABLE>
is that all 16 or 8?
Old Feb 16, 2006 | 03:45 PM
VtecKiDD's Avatar
16
Old Feb 16, 2006 | 04:19 PM
bks84's Avatar
Loved
i looked on nopi.com, but couldnt find them link please?
Old Feb 17, 2006 | 07:09 AM
VtecKiDD's Avatar
Part Number 318+0203 INTAKE
Part number 318+0202 EXHAUST
lude98SH
Aug 3, 2007 10:40 PM
1badteg
Jun 25, 2007 10:28 PM
rizq777
Apr 30, 2007 05:00 PM
Toadfart
Dec 6, 2005 12:50 AM
streetracerof06
Nov 29, 2005 06:43 AM
