quick question ... will 205/40ZR17s rub on stock EG?
Old Dec 5, 2005 | 05:16 PM
ibe2fly's Avatar
Default quick question ... will 205/40ZR17s rub on stock EG?
i have a 94 civ ex coupe ... everything stock ... will
17 Inch Konig Rims
with NT 450 205/40ZR17 Tubeless tires rub? if so what can i do to make them NOT, please no sarcastic remarks.
thank in advance
i need new tires for winter and this guy i know has a deal... these rims n tires for 450
Old Dec 5, 2005 | 05:25 PM
freakin_eLRoD's Avatar
Default Re: quick question ... will 205/40ZR17s rub on stock EG? (ibe2fly)
as long as the offset of the rim is correct, you shouldn't rub..
Old Dec 5, 2005 | 05:33 PM
Defile's Avatar
Default Re: quick question ... will 205/40ZR17s rub on stock EG? (freakin_eLRoD)
Shouldnt rub the well, i dont know how low you are going, but i'm really low, and i have 205/40/16's. I have about a 3" drop on mine, i dont even rub when hitting bumps and i have about an inch or so of space between the tire and fender. So if your not going past a 2" drop you should be fine. The offset is important, if your buying from a reputable dealer he should know wether a rims offset is going to work for you or not.
Old Dec 5, 2005 | 05:43 PM
broketuner-Sol_Si's Avatar
When I first got my car it was slammed (4" of ground clearance at the most) with that tire size. I hated it(lots of rubbing). then changed out the suspension to 1.75" lower than stock and loved it(no rubbing) I had my 17s until I hit a deep pothole going about 45mph . As long as you don't slam it you should be fine.
Old Dec 5, 2005 | 05:52 PM
ibe2fly's Avatar
Default Re: quick question ... will 205/40ZR17s rub on stock EG? (broketuner-egb16a)
so stock height i'd rub? i'm gonna def need to lower ?
Old Dec 5, 2005 | 06:35 PM
No on the stock height it should be ok, just don't go more than a 2" drop or rubbing will become an issue.
Old Dec 5, 2005 | 08:23 PM
ibe2fly's Avatar
thx imma pick up this week ill post pics
glofcheskie
Honda Fit
41
Feb 12, 2009 02:56 PM
enviousdm
Apr 11, 2006 05:42 PM
beaterman
Dec 27, 2003 07:20 PM
austrian type-R
May 10, 2002 07:29 AM
