Suspension & Brakes Theory, alignment, spring rates....
SPC lower control arms
Old Dec 5, 2005 | 04:59 PM
AMLS4dr200whp's Avatar
Default SPC lower control arms
hi there, alright I was wondering what lower controls arms really do. If its a good upgrade because Im doing my sway bars and tie bar. Since Im gonna have my suspension out I will also have my control arms out as well so I can do it one shot, so need opinions to do it or not.
PS. does the control arm kit includes urethane bushing let me kno
Old Dec 5, 2005 | 05:27 PM
PIC Performance's Avatar
Default Re: SPC lower control arms (AMLS4dr200whp)
Good for:
1. Replacing the stockers if they are destroyed during the swap, and you can get a good deal on them (cheaper than OEM).
2. Adding a swaybar, if your stock arms do not have holes for a swaybar (and you can get them cheaper than OEM units with swaybar mounting points)
3. If they have improved bushings, to reduce deflection compared to the stock ones.
Not good for:
1. Weight reduction
2. "Correcting" negative camber gained by lowering the car
All just my opinion.
Old Dec 5, 2005 | 11:16 PM
Tyson's Avatar
theyre pretty worthlesss pieces of bling as far as any typical user is concerned, i think.
and i recommend you ESPECIALLY dont get SPC LCA because they purposely mess with the length of the LCA by shortening it, and totally removing negative camber. which to me is not a positive thing. and will hurt your handling performance.
Old Dec 6, 2005 | 07:15 PM
Default Re: SPC lower control arms (Tyson)
thats a good point, heard about that
Kitsune
Apr 10, 2013 11:55 PM
Furious Styles
Apr 26, 2011 02:16 PM
blackccoupe
May 16, 2008 07:21 PM
pliskin679
Suspension & Brakes
Apr 30, 2007 01:10 PM
Teal5GenHatch
11
Jul 27, 2006 06:21 PM
