Abs light turned on when it justed started snowing !!!!????
Old Dec 5, 2005 | 04:07 PM
Ruskimafia's Avatar
Default Abs light turned on when it justed started snowing !!!!????
I ahve a 2000 accord and today was the first day it snowed in MD so i was leaving work and decided to see if the cars abs work so hit the brake tehy worked. i drove for about a minute and the light turned one. I read this has to d owith cold weather ? is that true?
Never Had this light turn on befor, and ABS Fluid is full
i wanna why it turned on
Old Dec 5, 2005 | 04:09 PM
iam7head's Avatar
Default Re: Abs light turned on when it justed started snowing !!!!???? (Ruskimafia)
probably you got some salt on the "sensor" wheel, make sure they are clean
Old Dec 5, 2005 | 04:19 PM
Ruskimafia's Avatar
Default Re: Abs light turned on when it justed started snowing !!!!???? (iam7head)
thats the problem no salt was put down yet it was in a parking lot right after i started the car i hit the brake and light turned on. SHould i go get it check out ? or was it because off the cold ?
Old Dec 5, 2005 | 06:08 PM
wingback44's Avatar
my ABS light turned on when it snowed to. i just turned my car off then back on and the light went away. it may have somethingto do withthe cold cause it was 3 degrees outside.
raene
May 30, 2013 03:13 AM
94coupeNA
Jan 26, 2006 12:56 PM
machinehead
Nov 5, 2003 01:59 PM
