92Si shell + 93cx engine harness = Help with Cruise Control
ok heres a quick run down:
i have a jdmb16, and had it in my 93 cx. crashed it and got a 92 si shell with no motor or anything. The cruise control box and plug in still under the hood, but the harness i have on my b16 came from my 93 CX which doesnt have Cruise.
where do i run the wires from the Cruise box under the hood to the motor? or do they not go to the engine harness at all??
thanks in advance
thanks in advance
ok where do i run the wires from the plug that comes from the Cruise control box? the vacuum lines arent a problem
If it is a 92 si it should just have a harness that runs along the driverside engine bay, and have a pigtail that plugs into the cc unit.
ok maybe ill take a closer look next time im at the car. its snowing here now and im not where my car is.
im pretty sure it was unplugged tho. looked like they unplugged it when they took the opld si motor out.
so ur saying the plugs are not part of the motor harness at all?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noh22eg »</TD></TR><TR><TD CLASS="quote">there is a cable for the cruise control</TD></TR></TABLE>
care to elaborate a bit more? like where does it go to and from and so u know anything about the wiring?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified »</TD></TR><TR><TD CLASS="quote">care to elaborate a bit more? like where does it go to and from and so u know anything about the wiring?</TD></TR></TABLE> I thought you said you already had an Si chasis, if so the second throttle cable for the CC just goes through the firewall, it doesn't go to the engine.
ok im not worried about the cables, i want to know about the plug that comes out of the box under the hood, mine isnt plugged in and i dont know if buddy jsut took the harness for it or what, know where to run teh wires to?
ok well i know that now, but where do the wires go?? i dont think the female end of the plug is there at all, does anybody where to run the wires if the plug isnt there?
I would sugest cutting open your loom where that pigtail should be entering it, finding the corresponding wires, extending them a few inches and re-wiring the Cruise Control, hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat »</TD></TR><TR><TD CLASS="quote">
thanks man, thats just what i needed. didnt know if that would work or not, hope i didnt seen too dense, just on a wiring expert
thanks tho
</TD></TR></TABLE>thanks man, thats just what i needed. didnt know if that would work or not, hope i didnt seen too dense, just on a wiring expert
thanks tho
alright here are the colors
BLK - BLK
BWN - BWN
BRW WHT trac. - WHT
BRW BLK trac. - BLUE
The colors on the left side are the bay harness, and the right side are the corresponding colors on the Cruise Control Unit. GL
BLK - BLK
BWN - BWN
BRW WHT trac. - WHT
hate to bring this back from the dead, but do EGs have a vacuum source for the CC or is it all electronic?
also where is the fuse for the CC located?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified »</TD></TR><TR><TD CLASS="quote">where is the vacuum canister? i looked on hondaautomotiveparts.com and couldnt see anything to do with a vacuum canister at all, only for 96-00 civics....</TD></TR></TABLE>
Nitrozity74
Nov 22, 2017 07:30 PM
