Beaks EK SRK/ITR 22mm rear sway: Impressions and Pics
Old Mar 14, 2002 | 12:49 PM
kent, clark's Avatar
Default Beaks EK SRK/ITR 22mm rear sway: Impressions and Pics
Good kit. Endlinks are forced to sit perpendicular to the ground in order to maximize their range of motion. Solid reinforcement plates on front and back. I needed to file a bit on the top inside corners of the front support plates in order to fit flush on the control arms. I ended up having to send these back to Wil to have them cut thinner as the sway bar brackets would not fit behind my muffler (GReddy SP). I got them back pretty fast and everything has been fine.
Driving impressions: Wow! The driving dynamics have completely changed on my car. Surprisingly neutral. Off-throttle oversteer is just a right ankle lift away. The rear feels very stable and solid. Turn-in is easy and the car tracks well in turns. All in all, a great mod for the money. Remember, it's the same bar used in the Comptech combo (ITR 22mm sway).
Total cost (all necessary parts and shipping): ~$230
The kit:
Shaved front support plates:
Rear view:
Side view:
Car: 98 DX hatchback
Other suspension mods:
Tokico Illumina Suspension Kit (5-way adj shocks/Prokit-like springs ~250F/150R)
16x7.5 43mm Kosei K1 Racing
205/45ZR16 Kumho ECSTA Supra 712
Generic front upper strut bar
Spoon rear upper strut bar
Rear Camber Kit
Old Mar 14, 2002 | 01:35 PM
CheezeFrog's Avatar
Default Re: Beaks EK SRK/ITR 22mm rear sway: Impressions and Pics (kent, clark)
Nice.. what type of bar are you using for the front?
Old Mar 14, 2002 | 04:47 PM
tonyxcom's Avatar
Default Re: Beaks EK SRK/ITR 22mm rear sway: Impressions and Pics (CheezeFrog)
I just installed my beaks/itr kit last night onto my 96cx. I didn't have any issues with fitment or clearance though. Bolted right up. And I still have the stock CX muffler too
I was suprised at what the bar did for me too. I have the CTR/SI front 26mm setup and without the rear sway, my car felt "twichy" on the freeway above 80mph. Now with the rear sway, the car is more stable at speed.
I also noticed that with only the front, my turn in was rather abrubt and undulations in the road would give me a little bump steer. Now with the rear sway that seems to have gone away.
Overall though, my car does feel more stable and planted, suprisingly the rear end isn't as loose as I thought it would be, even off throttle.
Only time will tell, I have only put 20 miles on the car since installing the bar last night.
Old Mar 14, 2002 | 05:56 PM
CheezeFrog's Avatar
Default Re: Beaks EK SRK/ITR 22mm rear sway: Impressions and Pics (tonyxcom)
What all parts were required for the Si front bar? Would I just need the swaybar, mounting bushings and endlinks?
Old Mar 14, 2002 | 07:35 PM
Jackson's Avatar
bar, end links, lca's, forks, and necessary bolts and chit.
Old Mar 14, 2002 | 07:42 PM
jrlude25's Avatar
Just wondering I have a 96 del sol s. What kind of front sway bars will I be able to install. For sure going with beaks and itr for the rear
Old Mar 14, 2002 | 07:47 PM
tonyxcom's Avatar
Default Re: Beaks EK SRK/ITR 22mm rear sway: Impressions and Pics (jrlude25)
I think on the del sols you can put any 94-00 integra front sways including ITR.
Someone please clarify
Old Mar 14, 2002 | 07:49 PM
tonyxcom's Avatar
Default Re: Beaks EK SRK/ITR 22mm rear sway: Impressions and Pics (Jackson)
"bar, end links, lca's, forks, and necessary bolts and chit."
Yeah, LCA's, end links, swaybar, damper forks, and swaybar bushings and brackets. The only bolts that are differnet are the lower fork bolts. Everything else is the same, including all the bushings and bolts that mount the LCAs to the subframe.
Old Mar 14, 2002 | 08:16 PM
None
Old Mar 14, 2002 | 08:20 PM
That's interesting that you went with a front bar first. I figured that if my car oversteered too much with just the rear bar, I would put in a front one. I'm pretty satisfied with how the car handles now...need to improve the nut behind the wheel.
Old Mar 15, 2002 | 04:24 AM
vntperformance's Avatar
Where can i get these from? I have a 95 CIvic CX Hatch, with this setup, what CA do I use? What sway bar? Does the cx come with a front sway bar, if not what do i use?
vnt
Old Mar 15, 2002 | 08:00 AM
KamikazeSol's Avatar
Just wanted to let you know I am working on a adapter bracket to make it posssible to mount a factory front sway bar on cars that do not have the holes in the lower control arms. This should make it much less expensive to modify the front bar. I am putting a 24mm GSR bar on mine and using my S lower controll arms. Send me an e-mail and when I get it set I will be selling the brackets.
Old Mar 15, 2002 | 04:10 PM
tonyxcom's Avatar
Well, I had always planned on running sways on both ends. I got the front first because I came across a deal I couldn't pass up on the CTR setup, and was still undecided on the rear (until Wil talked me out of the Mugen setup). I fugured if I didn't like the front only I could always disconect one of the endlinks. And I had tons of steering already, and wanted to control body roll more.
As a side note, you can tune the rear sway if you have the prothane or similar d-brakets. Since you can slide the brakets up and down, you can change the angle slightly of the ends of the sway bar. Moving the brackets up should should "stiffen" the sway bar and moving them down should "soften" the swaybar.
Please note that this wont yield results andwhere near moving the endlinks pivot on the end of the sway like a comptech setup, or with adjustable lenght endlinks.
Old Mar 15, 2002 | 04:18 PM
Cheap Bastard's Avatar
New User
I like the kit, but the stock ITR bushings have alot of play. Compared to Mugens bushings. The ITR's have big and fatty rubber bushing.
CB
Old Mar 15, 2002 | 06:07 PM
tonyxcom's Avatar
Default Re: Beaks EK SRK/ITR 22mm rear sway: Impressions and Pics (Cheap Bastard)
Will (Beaks) sent Prothane bushings with my kit
Old Mar 15, 2002 | 07:06 PM
seek167's Avatar
did the beaks kit cost 230.00 or is that the type r sway bar too.
[Modified by seek167, 11:16 PM 3/15/2002]
Old Mar 15, 2002 | 08:05 PM
Default Re: Beaks EK SRK/ITR 22mm rear sway: Impressions and Pics (seek167)
The Beaks kit cost me $65 shipped. The bushings, brackets, the bar itself, and the Si endlink$ make up the rest of that sum. Sounds like a lot but well worth the investment, IMO for a great-sized bar that won't tear out.
Old Mar 15, 2002 | 08:17 PM
seek167's Avatar
glad to here. have a good time with it.
Old Mar 15, 2002 | 08:33 PM
you lucky bastard
Old Mar 15, 2002 | 08:50 PM
tonyxcom's Avatar
Well, Will offered to source all the needed parts for me to save me the hassle of getting things shipped from about 4 differnet places. He asked if I wanted prothane instead of the itr ones and I said of course. So my total shipped was 250 even. Which is a bargain to me considering the hassle he saved me alone.
I can't say it enough...some of the best customer service I ever got and it was only for a $65 product.
Old Mar 16, 2002 | 08:03 AM
I figured that's what you meant. I concur: Wil's customer service and product =
Old Mar 16, 2002 | 09:19 PM
Cuong-nutz's Avatar
i cant see the picture
Old Mar 16, 2002 | 09:31 PM
Cuong-nutz's Avatar
i cant see the pictures
Old Mar 17, 2002 | 09:44 AM
Default Re: Beaks EK SRK/ITR 22mm rear sway: Impressions and Pics (wheresmyvxhb)
Here's the Pics
Here's the Pics
