Help with my B16a swap!!!
Old Dec 5, 2005 | 08:26 AM
jdmcivic1999's Avatar
Default Help with my B16a swap!!!
Ok so i just swapped a jdm b16a into my 99civic ex. now when i hook up the fuel line to the fuel rail and go to start it, it leaks fuel. now i went to honda and bought the little washers that go in between the fuel line and rail, i put those in and go to start my car and it still leaks gas. now i dont know if there is a difference between OBD1 fuel rails and OBD2 fuel rails?? or if there is a crack in the fuel rail itself. does anybody have any suggestions on what i should do?
Old Dec 5, 2005 | 09:02 AM
saywhat's Avatar
Default Re: Help with my B16a swap!!! (jdmcivic1999)
Take off the rail clean it, inspect it look for small imperfections on the mating surfaces,(if the rail looks ok); look at the line look for imperfections, make sure you arent putting the filter end on the rail and the rail end on the filter, look up the torque specs online and put it all together to factory spec and if it still leaks then you might have the wrong banjo bolt or something else is really wrong.
Old Dec 5, 2005 | 09:12 AM
9civichatch3's Avatar
NICE GUY
Default Re: Help with my B16a swap!!! (saywhat)
alos make sure you have the copper washer on
Old Dec 5, 2005 | 10:35 AM
saywhat's Avatar
Default Re: Help with my B16a swap!!! (9civichatch3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9civichatch3 &raquo;</TD></TR><TR><TD CLASS="quote">alos make sure you have the copper washer on</TD></TR></TABLE> If that isn't already what you bought from the dealership.
Kcnugz
May 30, 2014 05:39 PM
sohc1200cc
Nov 3, 2006 10:02 AM
MyCivic
Jun 6, 2006 05:19 PM
EFin' Kyle
Apr 27, 2006 11:43 PM
