90mm Pistons by CP *pics* N/A Nissan inside
Old Dec 5, 2005 | 05:52 AM
Onyxeros's Avatar
Default 90mm 12:1CR Pistons by CP *pics* N/A Nissan inside
12:1 CR
I thought you guys might be interested in my motor build (Nissan SRxxVE)
These pistons are for the VE head 90 mm with 16ve valve reliefs and are flat top.
The stock 16ve piston weighs 331g the 90mm ones below weigh 338g
They will be finished off with skirt coating and carrillo a-beam rods
Old Dec 5, 2005 | 06:12 AM
C-NYCE's Avatar
Default Re: 90mm 12:1CR Pistons by CP *pics* N/A Nissan inside (Onyxeros)
those motors will make plenty of power.
Old Dec 5, 2005 | 06:21 AM
m R g S r's Avatar
what was the stock compression? those pistons look like they have a decent sized dome on em....
Old Dec 5, 2005 | 06:24 AM
Onyxeros's Avatar
Default Re: 90mm 12:1CR Pistons by CP *pics* N/A Nissan inside (m R g S r)
stock compression was 11:1 but it was 68mm stroke. These are 12:1 on an 86mm stroke
Old Dec 5, 2005 | 10:39 AM
The Birdman's Avatar
damn those look nice... What displacement?
Old Dec 5, 2005 | 04:31 PM
lohatch's Avatar
Default Re: 90mm 12:1CR Pistons by CP *pics* N/A Nissan inside (jd3jdm)
90x86=2188 CC's or 133 C.I.
Old Dec 5, 2005 | 04:33 PM
Onyxeros's Avatar
Default Re: 90mm 12:1CR Pistons by CP *pics* N/A Nissan inside (lohatch)
thank you sir
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch &raquo;</TD></TR><TR><TD CLASS="quote">90x86=2188 CC's or 133 C.I.</TD></TR></TABLE>
Where did you get this info? Did he post the stroke, all I saw was the bore?
Edit: NM... Reading owns me....
Old Dec 5, 2005 | 04:45 PM
foot's Avatar
Are those off-the-shelf pistons? If not, did you go directly through CP? Any pics of the motor these are going in?
Old Dec 5, 2005 | 05:31 PM
Onyxeros's Avatar
Default Re: 90mm 12:1CR Pistons by CP *pics* N/A Nissan inside (foot)
i will get pics of the motor tomorrow, it's torn down right now.
the pistons are custom from CP and i ordered them through Modern performance inc in NJ. I will be happy to post the invoice number if you want a set
The intake manifold im using is from the Nissan Pulsar VZR N1 it has 2 injectors per runner. I will be running a set of 333cc and either 370cc or 259cc depending on what i need.
Chris
Old Dec 5, 2005 | 07:29 PM
thehatchninja's Avatar
keep us updated.
Old Dec 5, 2005 | 07:52 PM
leed's Avatar
Default Re: (thehatchninja)
Would love to see some pics of the build up and engine.
90x86, lucky bastard
Old Dec 11, 2005 | 09:25 PM
92TypeR's Avatar
FSAE
Default Re: (leed)
What is stock bore size? Is it a sleeved motor?
Its always fun to hear about other 4bangers that make good power N/A.
Old Dec 16, 2005 | 07:14 AM
Onyxeros's Avatar
Default Re: (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">What is stock bore size? Is it a sleeved motor?
Its always fun to hear about other 4bangers that make good power N/A. </TD></TR></TABLE>
Stock bore is 86mm
It will be benson sleeved
I look to this forum to help me understand what it takes to make good NA power
Because of this forum i am running flat top pistons and looking at getting a custom header made
Old Dec 16, 2005 | 08:01 AM
MAX_CFM's Avatar
Default Re: (Onyxeros)
you have a good bore and stroke ...
its going to come down to cams and cylinder head ..
and a non restrictive intake and TB and a properly designed header ...
you put all those together and you will make good power
iluvmydc4
Jan 29, 2008 09:42 AM
j0nb0y22
Oct 3, 2007 12:17 PM
BLK99VTECR
Jan 19, 2005 06:40 PM
Derek14
Feb 29, 2004 03:35 PM
blazin
Jul 11, 2003 06:11 AM
