what ecu for a d16y8 in a ef
Old Dec 5, 2005 | 12:30 AM
beaneg6's Avatar
Default what ecu for a d16y8 in a ef
is it possible to run a obd-0 b16 ecu on a single cam or will there be problems? or what ecu/suggestions do you guys have
Old Dec 5, 2005 | 08:34 AM
crxnj's Avatar
Default Re: what ecu for a d16y8 in a ef (beaneg6)
Its gonna run a little rich running a dohc program on a sohc motor..
I suggest converting to obd1 and getting a p28,,
Old Dec 5, 2005 | 08:39 AM
dr_latino999's Avatar
I would suggest in this order -
OBD-1 Conversion + P28 Chipped with correct P2P maps
TurboEdit + Correct P2P Maps + A creative way to spark up VTEC
Old Dec 5, 2005 | 04:19 PM
SVOboy's Avatar
No one has made good maps for the d16y8 in TurboEdit, I don't think, best bet it to chip a p28 for it and set dizzy timing to 12 degrees.
Old Dec 5, 2005 | 07:45 PM
beaneg6's Avatar
are there any problems in running a b16 ecu on a single cam...i heard there are knock sensor problems??? or something
Old Dec 5, 2005 | 08:07 PM
SVOboy's Avatar
Just general don't do it unless it's chipped problems. Pig rich, timing is off, I could take some screenshots and show you the difference between the maps if you wish.
Old Dec 5, 2005 | 11:40 PM
beaneg6's Avatar
so is there an obd-0 to obd-1 conversion harness? od do you have to wire it up
Old Dec 6, 2005 | 08:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaneg6 &raquo;</TD></TR><TR><TD CLASS="quote">so is there an obd-0 to obd-1 conversion harness? od do you have to wire it up</TD></TR></TABLE> You can do both if you want You can either purchase a Jumper harness from the lovely gents at http://www.rywire.com/ or you can wire it yourself.
Old Dec 6, 2005 | 08:27 AM
beyondspexj's Avatar
from obd0-obd1 you need more than just the jumper harness.
you will also need the obd1 injectors with matching clips, remove the injector resistor box and a 4 wire o2 sensor. p28 is the way to go
Old Dec 6, 2005 | 09:17 AM
Default Re: (beyondspecs_jamar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyondspecs_jamar &raquo;</TD></TR><TR><TD CLASS="quote">from obd0-obd1 you need more than just the jumper harness.
you will also need the obd1 injectors with matching clips, remove the injector resistor box and a 4 wire o2 sensor. p28 is the way to go</TD></TR></TABLE> Don't need new injectors, you can use your old ones.
Old Dec 6, 2005 | 09:47 AM
Rywire's Avatar
Default Re: (dr_latino999)
For sure go with the p28 ecu IMO
j_mee_5
Mar 21, 2011 09:14 AM
honisoto
Jan 24, 2009 04:01 AM
egboostin6
Mar 20, 2007 12:28 PM
JH4DC231
Aug 17, 2005 11:46 PM
willyboyK20
Jan 29, 2002 05:03 PM
