H22A Civic Shift Linkage Problems. Any idea for you H22A gurus?
Old Dec 4, 2005 | 04:25 PM
cpforyou's Avatar
Default H22A Civic Shift Linkage Problems. Any idea for you H22A gurus?
Hello. I have a H22A in a 92-95 Honda Civic Coupe.
My shift linkage broke. So now I'm trying to replace it.
I purchased shift linkage from a 1995 Honda Prelude VTEC, but when I tried to put it in, it was too short. I have a custom motor mounts (by Dr. Charles) and my shifter box is welded in, a little farther back than how it is normally mounted today.
Does anywhere know if there are any other shift linkages that would fit but are longer? Does anyone know if the 94-97 Accord Shift linkages work, and if they are longer or shorter?
CLIFF NOTES:
I have an old school swap. The motor sits differently and the 92-96 Prelude Shifter Assembly is WELDED. I cannot change that. The shifter box sits back more than swaps done today. The motor sits a little more forward than swaps done today. Therefore, the cables I have are TOO SHORT!
My original cables fit, and I don't know what car they came out of. I purchase shift linkage from a 95 H22A Prelude, and they were shorter by a few inches.
90-93 Accord shift linkage is different part number from 94-97 Accord. 92-96 Prelude is also different part number.
Which one is the longest?
Modified by cpforyou at 8:15 PM 12/4/2005
Old Dec 4, 2005 | 05:16 PM
UrbanEh's Avatar
Default Re: H22A Civic Shift Linkage Problems. Any idea for you H22A gurus? (cpforyou)
Try to route it differently. When I installed mine it took a few tries to get it right. Try going around the steering rack differently. Theirs my two cents if it helps. Good luck
Old Dec 4, 2005 | 07:12 PM
scUba-stEve's Avatar
Default Re: H22A Civic Shift Linkage Problems. Any idea for you H22A gurus? (UrbanEh)
an idea???...h2b kit...hahaha.
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UrbanEh &raquo;</TD></TR><TR><TD CLASS="quote">Try to route it differently. When I installed mine it took a few tries to get it right. Try going around the steering rack differently. Theirs my two cents if it helps. Good luck </TD></TR></TABLE>
Lets try this again. I have H22A Civic that has been running for many years. The shift linkage broke. I bought a set used for someone, and the cables are SHORTER..... LITERALLY! So my question is what is the LONGEST linkage that would fit in a 92-96 Prelude shifter box assembly.
I have a perfectly running H22A. I just need to replace the cables...that's it
Old Dec 5, 2005 | 03:31 PM
skunked's Avatar
I know some cables are longer than others however I'm not sure which ones those are.
Bump for some answers
Old Dec 5, 2005 | 03:40 PM
Mikey3000's Avatar
Default Re: H22A Civic Shift Linkage Problems. Any idea for you H22A gurus? (skunked)
is there a dang part number on your older shift linkage?
Old Jan 13, 2006 | 05:22 PM
cpforyou's Avatar
Default Re: H22A Civic Shift Linkage Problems. Any idea for you H22A gurus? (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">is there a dang part number on your older shift linkage?</TD></TR></TABLE>
To make it work, I called around. Had custom ones made.
96integralsvtec
Feb 6, 2008 11:27 PM
spidersam
Mar 12, 2007 02:19 AM
crazi_E
Jan 3, 2005 07:55 PM
