Best option for block/motor setup help...
Old Dec 4, 2005 | 04:21 PM
Samuels's Avatar
Default Best option for block/motor setup help...
I'm thinking of trading my swapped EF hatch for a EG hatch. The car was a LS/Turbo it was supposedly built by John at absolute pro-formance in Finksburg,MD. The car is said to have run a 13.2 on 8lbs of boost. The guy i'm getting it from was only running a AFC if i'm not mistaken for fuel management. He had a friend hook up a greddy profec b and supposedly hooked it up backwards somehow and spiking 28 psi cracking the sleeve. The spring in the wastgate was also removed. The motor supposedly has crower valvetrain and SRP 9:1 PISTONS and eagle h-beam rods. The head,rods and pistons were supposedly check out by a machine shop in MD and are okay but the pistons need rings. I'm gonna have my machine shop check the parts out. The guy is including a donor block but its been sitting in the rain according to him but was in running condition beforehand. Is this gonna be useable??? If so what else should I buy besides piston rings for the block??
He is including the AFC,RC 550'S and a blox 12:1 fmu the last 2 was'nt installed before hand..
I only wanna run 8-10psi and want a 13 sec car thats reliable. I really don't want to run the AFC or the FMU what is the cheapest solution to tuning??
The car is a 92 vx and has a LS tranny. What is my best option here should I sell the head it has the crower valvetrain,cam gears etc and the pistons,rods,afc,fmu,550's ??
I can get a 94 LS motor locally with 90k for 600 at the junkyard. I can get a b20 from noyan for probably right around that but i've heard the sleeves are to weak for boost without getting it sleeved. I can also get a gen 2 b16 motor locally for 650 but the miles are unknown??
What is my best option here?? MY goal is only 8-10psi the turbo is a t3/t4 56intake 60 exhaust but the whole system is welded to the whole exhaust which sux..
If this is the wrong forum please move it for me thanks just wanting some advice before I make mistakes wasting money... thanks
Old Dec 4, 2005 | 05:41 PM
Samuels's Avatar
Default Re: Best option for block/motor setup help... (Samuels)
c'mon guys help brotha out...
h22apwrd95
Nov 10, 2007 10:30 PM
ek9tl
May 11, 2007 02:50 PM
ORANGE EF
Jul 12, 2006 04:23 AM
b_jamin
Mar 19, 2004 02:55 AM
CRVRX
May 27, 2003 07:08 PM
