Metal chips found in oil pan and in head
Old Dec 4, 2005 | 02:01 PM
trecool44's Avatar
Default Metal chips found in oil pan and in head
I just picked up this motor (f22b2) yesterday. I took of the oil pan and noticed some small metal flakes. They are copper colored and are flat and jagged. I found the same flakes when i took off the valve cover. This motor recently had the head gasket replaced when puttin on a new head. The on ly thing i can think of is pieces of the old head gasket. Please help me figure out what the flakes are?
Old Dec 4, 2005 | 02:22 PM
Chiovnidca's Avatar
Default Re: Metal chips found in oil pan and in head (trecool44)
A busted up bearing maybe? Have you checked the rod and main bearings?
Old Dec 4, 2005 | 04:45 PM
trecool44's Avatar
bump for some answers
Old Dec 4, 2005 | 06:25 PM
trecool44's Avatar
ump
Old Dec 4, 2005 | 09:41 PM
imm0rt41's Avatar
Where do you live? It almost sounds like it could be localized rust.
Old Dec 4, 2005 | 10:35 PM
96CivicBoostCoupe's Avatar
Default Re: Metal chips found in oil pan and in head (imm0rt41)
i'll go with burned up bearing remains
Old Dec 5, 2005 | 03:12 AM
Chiovnidca's Avatar
Default Re: Metal chips found in oil pan and in head (96CivicBoostCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96CivicBoostCoupe &raquo;</TD></TR><TR><TD CLASS="quote">i'll go with burned up bearing remains</TD></TR></TABLE>
He doesn't seem to like that answer.
Old Dec 5, 2005 | 04:52 AM
AutoXer's Avatar
Default Re: Metal chips found in oil pan and in head (Chiovnidca)
Copper = bearings. It's about the only thing in there that could make copper flakes.
Old Dec 5, 2005 | 05:47 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trecool44 &raquo;</TD></TR><TR><TD CLASS="quote">I just picked up this motor (f22b2) yesterday.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">He doesn't seem to like that answer.</TD></TR></TABLE>
I can see why.
Another vote for bearing(s).
Old Dec 5, 2005 | 07:21 AM
BiG Chris's Avatar
i also going to say bearings
Old Dec 5, 2005 | 07:32 AM
Jimmy's Avatar
Global Moderator
Pull the oil pan all the way off and check out your bearings.. and get ready to spend some money!
Old Dec 5, 2005 | 03:32 PM
trecool44's Avatar
Is there any chance it could be remains of the old head gasket?
Old Dec 5, 2005 | 03:39 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trecool44 &raquo;</TD></TR><TR><TD CLASS="quote">Is there any chance it could be remains of the old head gasket?</TD></TR></TABLE>
Unless the block or head have been o-ringed, I doubt there would have been a copper headgasket on it.
Old Dec 5, 2005 | 03:41 PM
trecool44's Avatar
the headgasket on the motor was replaced recently, so maybe they left some around. Or maybe im tryin to give myself hope that this motor is still good
Old Dec 5, 2005 | 04:55 PM
hotimportcrx's Avatar
its defiently the bearings.......ill bet anything
Old Dec 5, 2005 | 04:58 PM
Default Re: Metal chips found in oil pan and in head (hotimportcrx)
if you had just picked up the motor you really should change all the bearings and put new rings on ....and then put some rod bolts....and your motor would be FRESH!!!!!!!!!!!
Old Dec 5, 2005 | 05:05 PM
Kamin's Avatar
bearings are done.
Old Dec 5, 2005 | 05:16 PM
Civic4less's Avatar
Default Re: Metal chips found in oil pan and in head (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trecool44 &raquo;</TD></TR><TR><TD CLASS="quote">the headgasket on the motor was replaced recently, so maybe they left some around. Or maybe im tryin to give myself hope that this motor is still good </TD></TR></TABLE>
Denial isn't just a river in Egypt my friend.
Like everyone else says... its most likely the bearings.
duck22krazy
Nov 3, 2008 07:44 PM
b16a1eg6
Oct 25, 2007 11:23 AM
hidiouskinky
Aug 9, 2007 08:00 AM
rc90hatch
Jan 10, 2006 05:49 PM
leprechaun117
10
Feb 2, 2003 02:58 PM
