WTB: D-Series 5-spd components for swap
I just recently got a jdm d15b vtec and I am going to do the auto/manual swap at the same time. The only problem is the junkyards around here are dry. So help me piece together my swap H-T.
Car: 1992 Honda Civic DX hatch w/ tired D15B7
Looking for:
Pedal Assembly w/ Clutch MC & D-series manual throttle cable
Hard and soft lines for clutch
possibly pressure plate & flywheel including all bolts/hardware
Shift linkage & shifter w/ all hardware
PM me with info please. TIA.
If anyone wants any of the left over auto components after the swap, I'd be willing to sell for cheap or trade.
Looking for:
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
i got a oem clutch and flywheel in great condition.( $100 shipped for both) also have a shift linkage and shifter Assembly. $35 shipped
Thanks for all the responses guys... PMs sent. Still looking for word on a clutch master cylinder / lines, manual throttle cable, and pressure plate w/bolts (flywheel bolts too). Keep 'em coming guys.
i got your pressure plate with bolts and flywheel bolts, your throttle cable and shift linkage like said before if you want them, make an offer on all of it, PM me though
hey guys, everyone has been pm'd...
1QwIkEf is hooking me up with shiftlinkage/shifter/bitchpin & clutch/flywheel/fw & pp bolts
still looking for master cylinder (w/ resevoir & bolts), hard & soft lines, d-series manual throttle cable, pedals, & pressure plate... I decided i'm just going to crap out and buy a new slave cylinder. Make sure to check your pms guys... I work 11 hours a day so pretty much the only time i get online is after 9 PM central time.
Thanks for all the responses!
the pressure plate will come with the clutch im selling you also... and bump for the rest of your parts
Alright... thanks for the outpour of offers everyone. I believe I have everything now except a P08 ECU or a P28.. really would like the P08 tho for the D15B vtec... but i don't know if i'll have money for it (much less the off-time for the swap) until the beginning of the year (unless someone has one for cheap).
final parts list (minus ECU)
1QwIkEf-
Shift Linkage/Shifter/bitchpin
Clutch/Flywheel/Pressure Plate/ & all bolts
mike93eh-
Master cylinder (w/ hardware & fluid resevoir), hard & soft lines, slave cylinder, and throttle cable
bebfsu1-
pedals
If someone notices something I am missing for this swap, please reply.
Thank you all. When I do the swap, expect massive writeup with pics in the 92+ Civic/Del Sol forum.
1QwIkEf-
mike93eh-
bebfsu1-
pedals
you will also need to get a motor mount for the tranny side. you cant use the stock manual one or the auto one. pm Newman he sells them on here. also do you have the rear trans bracket for the manual trans if not i can hook you up with one of them to.
byronl
44
Apr 11, 2006 03:53 PM
Toolman
May 17, 2005 08:18 AM
