ECU ?????
Old Dec 4, 2005 | 12:04 PM
D_CRX_Si's Avatar
Default ECU ?????
Im getting a infinite blinking code. It will not stop blinking when key set on on position...Is there a symptom on why it does this? Or why does it do this.?
Old Dec 4, 2005 | 12:38 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: ECU ????? (D_CRX_Si)
count the blinks there should be a long off period. then count till the off agin. thats the code(s)
also some car motor ecu info would be helpfull
Old Dec 4, 2005 | 03:11 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D_CRX_Si &raquo;</TD></TR><TR><TD CLASS="quote">Im getting a infinite blinking code. It will not stop blinking when key set on on position...Is there a symptom on why it does this? Or why does it do this.?</TD></TR></TABLE>
Read this and it will answer all of your questions.
https://honda-tech.com/zerothread?id=468260
Old Dec 4, 2005 | 07:30 PM
D_CRX_Si's Avatar
Default Re: ECU ????? (DieMaster)
91 crx si d16..Believe me theres no long off period, i sat there for 97 straight blinksthen i turned it off.
Old Dec 4, 2005 | 08:46 PM
VtecSyndrome's Avatar
If seen ECUs do that when they go bad, not all do that when they are bad but I never saw one do thatg that was not bad...........sorry this news is also bad....
Old Dec 4, 2005 | 09:43 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: ECU ????? (VtecSyndrome)
are you sure it isnt just blinking a code 1..
that would be o2 sensor if it is code 1. which would be very common and very easy.
you might just disconnect your battery and reconnect it.. and see if that clears it. if not, get a new o2 sensor. they are like $30.
Old Dec 11, 2005 | 07:56 PM
D_CRX_Si's Avatar
Alright, got more info on the problem.
As im driving the car for a period of time, the check engine light comes on and it feels like i lose bottom end...As i take of it isnt as quick of a response as it is when the ligh t is off, but when i get about 4,000 rpm it kicks and i gain power but light stays on.
Is any of this familiar to yall and do yall know what it could be?.
Any help Needed, thanx!!!!!!!!!!!!
Old Dec 12, 2005 | 02:14 PM
D_CRX_Si's Avatar
Bump!!!
Old Dec 13, 2005 | 03:29 PM
D_CRX_Si's Avatar
Work Bump!!!!
Old Dec 13, 2005 | 03:37 PM
drdisco69's Avatar
Default Re: (D_CRX_Si)
Sounds like an O2 sensor code, which is code 1... How many seconds between each blink?
Old Dec 22, 2005 | 04:53 PM
D_CRX_Si's Avatar
Default Re: (drdisco69)
Its about a second between every blink...its constant....??????????? Any help?
Old Dec 22, 2005 | 05:18 PM
D_CRX_Si's Avatar
BUMP!
Old Dec 22, 2005 | 07:17 PM
DieMaster's Avatar
try unpluging the map sensor. that will give u code 3 then compair the 2 and see if it is indeed a code 1 your staring at.
92 gs INTEG
Jul 2, 2007 11:50 PM
slowpokecivic
Feb 20, 2007 04:59 PM
bigislandc2
Aug 31, 2006 09:15 PM
iwhichisme
Apr 1, 2004 05:41 AM
Prelude Vtec 23
Jul 20, 2003 06:05 AM
