CRank PULLEy now wobbles.....
earlier my crank pulley was lose and amke noise i found a new ghetto way to tighten it...and now its tight with no noiuses but it wobbles........is that safe?? to drive ot get around for now?
if i explain it is hard,,,,,i had suttin to tighten it with a regualr wrech...so i put it on the bolt the left the wrenc by the axle and turn the car on it wont let it cuz the wrecnh will behittin axle ....trie that 4 5 times and it tighten it.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scarface50370 »</TD></TR><TR><TD CLASS="quote">why?</TD></TR></TABLE>
because of this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scarface50370 »</TD></TR><TR><TD CLASS="quote">if i explain it is hard,,,,,i had suttin to tighten it with a regualr wrech...so i put it on the bolt the left the wrenc by the axle and turn the car on it wont let it cuz the wrecnh will behittin axle ....trie that 4 5 times and it tighten it.....</TD></TR></TABLE>
we really cant help you if you dont know how to type
because of this:
oh...thats cuz if u READ the guy asked me how did i tightened it..so i worte it was gonna be hard to explain dude...my onli question is where can i drive the car to to tighten it 133ft lb
OK. I put a wrech on the pulley bolt like if i was gonna tichten it now i was able to tighten to a certain point till it moved. so most people say SLAM YOUR BRAKES...or STICK A SCREDRIVE....me i simple let the wrech with the metal piece of the wrench by the wheel axle and cranked the motor and that tighten it.
Let me see if I got this right...you put a wrench on the crank bolt and then cranked the engine to tighten it? Are you out of your mind?!?!?!?
You probably bent the crankshaft. Is oil pouring out the front seal too?
nah its not........took the car for a long spin....no oil leak at all...noise is gone....cars fine..i actually tried it a few more times and now it doesnt wobble at all..but i still awanna make sure its at 133ft so ima go buy a torque wrench
drop out the driverside motor mount. let driverside hang down a bit, supported by a jack.
have a friend torque one way with a breaker bar and you tighten it with your torque wrench to 133lbs.
works every time.
a $20 chain wrnech from your local parts store will do the trick.
works every time.
I cant belive you dident snap the bolt doing that, that is the worst idea I have ever heard of to be honest.
Get the correct tool to hold the pully in place its called a harmonic dampner pully holder thingie (everyone calls it something else but it holds that pully). Now tighten it down to spec but I would take it off to make sure you dident mess something up like Im sure you did if its wobbling. I mean if its not tight even it should wobble unless something is bent somewhere or messed up all it will do if its lose will slide back and forth but it should NEVER wobble.
LOL... jea i know the idea was kinda dumb but i was so impatient..heres the status of it..is just like u say it moves a lil bit back and forth.....barely noticeable.....before it was way worse making noises..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scarface50370 »</TD></TR><TR><TD CLASS="quote">OK. I put a wrech on the pulley bolt like if i was gonna tichten it now i was able to tighten to a certain point till it moved. so most people say SLAM YOUR BRAKES...or STICK A SCREDRIVE....me i simple let the wrech with the metal piece of the wrench by the wheel axle and cranked the motor and that tighten it.</TD></TR></TABLE>
Don't ever do this ever again. All you need is a big chain wrench and friend to hold while you tighten it.
Oh and Im def never gonna buy a car from you.
psicrxsi
Apr 17, 2005 12:58 PM
