Removing a/c and a/c harness.....this look about right?
Old Dec 4, 2005 | 10:19 AM
crexer's Avatar
Default Removing a/c and a/c harness.....this look about right?
Ok had my a/c out for a few years now and I had just left the relays/harness in tact and wanted to clean up some wiring. This is basically what I got removed and im just making sure that nothing will be need any longer. I had to unplug 1 white plug with 1 wire from the fuse box, and what appears to be a ground on the firewall up underneath the dash/heater box to remove this whole harness. Is this what y ou guys came up with?
Old Dec 4, 2005 | 10:29 AM
Markb16a's Avatar
yeah thats it. good job.
Old Dec 4, 2005 | 12:24 PM
crexer's Avatar
Default Re: (Markb16a)
awesome, can anyone else confirm for sure before I throw this in the trash?
Old Dec 4, 2005 | 12:28 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (crexer)
if u dont want the harness can i have it?
also i dont remimberthat under te blower. it's not there on my ac sedan.
Old Dec 10, 2005 | 02:58 AM
crexer's Avatar
Default Re: (DieMaster)
any reason why my car may be throwing code 20 ELD after removing this harness?
Old Dec 10, 2005 | 05:52 AM
crxgator's Avatar
because you removed the wrong harness...
Old Dec 10, 2005 | 08:58 AM
crexer's Avatar
Default Re: (crxgator)
this is not the a/c harness with relays? its all one peice....
Old Dec 10, 2005 | 09:33 AM
Boosted Chemist's Avatar
eld system is in the fuse box you might of disconnected it
Old Dec 10, 2005 | 10:50 AM
NCchris's Avatar
Default Re: (Boosted Chemist)
Looks just like the harness I removed, 3 relays and several plugs.
chris
Old Dec 10, 2005 | 05:33 PM
crxgator's Avatar
Default Re: (NCchris)
looks different to me...there isnt the ac fan plug, and the two relays by the headlights are connected together by a metal bracket...
Old Dec 11, 2005 | 04:47 AM
NCchris's Avatar
Looks to me like the two relays on the left would be the ones on the metal bracket by the passenger headlight. Fan plug could have already been removed along with the part of the harness that goes from the two relay assembly across to the fan and compressor. Should be a single red wire that plugs into the compressor at the end of this harness.
HTH
chris
b1699dx
Sep 24, 2012 10:03 AM
blue_hatch
May 20, 2011 01:24 PM
skUnK2jdm
Mar 10, 2007 09:26 AM
coolguy660
Aug 30, 2006 09:45 PM
