What ECU best fits my needs?
What ecu should I pick up. I'm picking up a JDM GSR without an ecu, so I need to figure out which ecu I should get. I don't mind going OBD1 but I already have a OBD0 B16 ecu, so my poll will hopefully decide which ecu will be best for me.
Mods will be
3 Inch Intake
Type-R cams
Skunk 2 IM
Vibrant Headers
Thanks in advance
Mods will be
3 Inch Intake
Type-R cams
Skunk 2 IM
Vibrant Headers
Thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold EF »</TD></TR><TR><TD CLASS="quote">obd 1, doesnt matter gsr or b16</TD></TR></TABLE>
The ODBI GSR ECU is best, since it is the right ECU for the motor. The USDM P72 would work okay as well. But unless you can get a P30 cheap, why bother? And as you know, I don't like the pre-1992 stuff.
The GSR ECU is the correct ECU, but IMO he should only get it if he has the stock GSR IM or if he wants to be able to use his knock sensor. He has a Skunk2 IM so IAB control isn't needed. I would say get a chipped OBD1 P28 from kenji. He can give you a chip with fuel and timing maps optimized for your mods.
https://honda-tech.com/zerothread?id=1300672
look i'm having the same problem my ecu is kinda messed up and i'm planning to change it but i dont know which one alot of people are telling me that if you have a b series engine you can put anything aslong as it's a b series part so i'm probably going to but a b18 ecu on to my b161a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yuyo »</TD></TR><TR><TD CLASS="quote">look i'm having the same problem my ecu is kinda messed up and i'm planning to change it but i dont know which one alot of people are telling me that if you have a b series engine you can put anything aslong as it's a b series part so i'm probably going to but a b18 ecu on to my b161a</TD></TR></TABLE>
obd0 not= obd1
obd0 not= obd1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yuyo »</TD></TR><TR><TD CLASS="quote">not everyone's perfect here so you dont have to correct everyone </TD></TR></TABLE>
sorry, wasnt trying to be a jerk, just figured you might run into the same kinda trouble i did before.
i figured you thought that any b16x computer can be used with any b18x. but b18's have not just b18a/b, but also b18c, which is obd1-obd2
b18a/b can be pre obd, obd1-2 same with b16a
NA_EF_8
May 13, 2007 11:46 PM
