SPOON clutch setup-disk + pp????
Old Mar 14, 2002 | 08:03 AM
Integra_B18B's Avatar
New User
Default SPOON clutch setup-disk + pp????
Is anyone running this setup?? Pros and cons??
I don't have an ITR but have a base Integra and was wondering what you guys think of this clutch because I may pick one up.
Thanx
Old Mar 14, 2002 | 08:05 AM
Reid's Avatar
Global Moderator
Default Re: SPOON clutch setup-disk + pp???? (Integra_B18B)
non-VTEC and VTEC trannies use the same clutches and flywheels?
Old Mar 14, 2002 | 08:09 AM
New User
Default Re: SPOON clutch setup-disk + pp???? (Reid)
I'm pretty sure, cause I was told that I can use a stock ITR flywheel and clutch on my non-vtec Teg...
Hope that's true!!
Old Mar 14, 2002 | 09:05 AM
New User
Anyone????????
Old Mar 14, 2002 | 09:13 AM
98TypeR's Avatar
it grips harder than stock. when i had mine, i was able to chirp 3rd to 4th. could do it with the stock clutch. My car had 190 hp at the time.
Old Mar 14, 2002 | 09:19 AM
AJ PwR's Avatar
Spoon flywheel is one of the lightest billet 1 pce flywheel (which I noticed ATS was lighter 1 pce no holes). Spoon claims the sports clutch has 30% more grip over stock ITR and the pedal feel will be pretty much like stock.
Old Mar 14, 2002 | 10:22 AM
B2FiNiTY's Avatar
Default Re: SPOON clutch setup-disk + pp???? (AJ PwR)
Will the spoon flywheel have any problems with the starter?
Old Mar 14, 2002 | 07:12 PM
New User
AJ PwR, I tried e-mailing you but it didn't work for some reason. I want more info about the SPOON clutch setup.
Thanx
Old Mar 14, 2002 | 07:36 PM
Spikey's Avatar
Default Re: SPOON clutch setup-disk + pp???? (B2FiNiTY)
none at all
Old Mar 14, 2002 | 11:53 PM
AJ PwR's Avatar
The Spoon flywheel weighs 4.2kg and it is the lightest flywheel with no holes. Too light of a flywheel will loses balance of the crank and you will end up losing torque.
Spoon clutch can hold up to 250whp so ir is pretty for NA setup.
Old Mar 15, 2002 | 06:18 AM
Black_eh2's Avatar
New User
does the spoon clutch kit come with everything needed for a clutch swap?
Old Mar 15, 2002 | 07:17 AM
Larkin W.'s Avatar
Default Re: SPOON clutch setup-disk + pp???? (SleeperEG6)
I was gonna go Toda/exedy on my Si. But i recently decided im gonna do Spoon clutch and flywheel. I like spoon's flywheel and the clutch is better than exedy so thats my conclusion. Now if i only had my tax return check
Old Mar 15, 2002 | 12:35 PM
mafay2's Avatar
New User
Default Re: SPOON clutch setup-disk + pp???? (EbboyPSi)
My friend just installed the Spoon flywheel and clutch set up. He said the pedal feel is almost like stock, but it grap a lot better than stock. He did complain about the price is a bit expensive, but he still like it.
Old Mar 15, 2002 | 12:45 PM
98TypeR's Avatar
Default Re: SPOON clutch setup-disk + pp???? (mafay2)
2 things that i will say sux about this combo.
First, they do not include a clutch alighment tool.
and Second, to secure the pp to the flywheel, they use these lame *** hex screws. I recommend you replace these with regular metric bolts.
Old Mar 15, 2002 | 01:43 PM
whiteGSR's Avatar
Default Re: SPOON clutch setup-disk + pp???? (98TypeR)
how much whp is the stock ITR clutch good for???
crazy eyez killa
Mar 4, 2004 02:48 AM
underrated99si
Jun 13, 2002 10:31 AM
wdyno
Oct 23, 2001 11:39 AM
EleanoR
Sep 6, 2001 12:09 PM
