Multimeter tests...What settings?
I bought a $20. multimeter from Autozone.Its a ACTRON brand.
Im testing the coil and ignitor in my distributor.My HELMS says to put the + at the A terminal and - at the B terminal and I should read 0.6-0.8 ohms.
What setting to I put the multimeter on?Heres the best pic I could find of it.
Also it says resistance will vary with coil temp., specs. are at 68 F.
How much will it vary with it being 59 F outside?
Thanks
Thanks
Is there a setting that looks like this?
The meter might auto range. go ahead, put it on that setting and hold each terminal with each hand.
^^ not a joke, honest.
^ amperage for current flow... but yeah if you're measuring for resistance look up that ohm symbol. also make sure you measure resistance with no power to whatever you're measuring meaning it's been disconnected.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 »</TD></TR><TR><TD CLASS="quote">
^^ not a joke, honest. </TD></TR></TABLE>
That thing is huge!
Anyways yeah theres a OHM sybol but theres 200 2000 20k 200k 2000k.
I disconnected the white/blue wire and black/green.
Under 200 OHM from
A-terminal to B-terminal I got 1.2.Its supposed to be 0.6-0.8
A-terminal to secondary winding I got 9.0 Its supposed to be 12.8-19.2
The digi screen is supposed to jump around in number then finally stop right?
Bad coil
That thing is huge!
Under 200 OHM from
Bad coil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy »</TD></TR><TR><TD CLASS="quote">^ amperage for current flow... but yeah if you're measuring for resistance look up that ohm symbol. also make sure you measure resistance with no power to whatever you're measuring meaning it's been disconnected.</TD></TR></TABLE>
yeh good call on the power. btw, you wont meaasure any aperage unless you have a resistance
DanInOttawa
Jun 20, 2013 10:29 PM
JSIR
May 16, 2002 04:41 PM
