Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
what rear camber kit is good for autox?
Old Dec 3, 2005 | 12:47 PM
super_nguyen's Avatar
Default what rear camber kit is good for autox?
what adjustable upper control arms do you guys run in the rear? i seen pictures of the T1R and some of the ingalls, the ingalls has a larger bushing, but the T1R structure looks like the better build. the car is a 99 EK civic coupe, and i am trying to set up my car for daily driving with the occasional weekend autox. any input?
Old Dec 3, 2005 | 12:48 PM
jeffhaut's Avatar
Default Re: what rear camber kit is good for autox? (super_nguyen)
are you trying to add camber or take it away? to remove camber you can just add washers and longer bolts to where the upper control arm mounts to the car. this is not recomended however because camber is a good thing for handling
Old Dec 4, 2005 | 12:57 AM
Default Re: what rear camber kit is good for autox? (jeffhaut)
i am planning on lowering the car but its gonna be a daily driver, i would rather not wear the inner side of the tires out, i've heard of the washer method, but i want to be easily adjustable.
Old Dec 4, 2005 | 05:29 AM
solo-x's Avatar
a couple of these...
and a couple of these...
Old Dec 4, 2005 | 09:06 AM
jeffhaut's Avatar
and camber will not eat tires all that bad if you have zero toe. ive been running -2 degrees on my car daily driven and autoXed every weekend from august to october with no extra inside wear on my hankook RS-2's. i had a set of es100's before this that only lasted 4 months under the same use because my toe was out
Old Dec 4, 2005 | 09:14 AM
Default Re: (jeffhaut)
alright thanks guys, when i drop my car if the camber and toe out isn't too bad i'll just leave it as is.
Old Dec 4, 2005 | 09:44 AM
.RJ's Avatar
.RJ
Default Re: (super_nguyen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_nguyen &raquo;</TD></TR><TR><TD CLASS="quote">when i drop my car if the camber and toe out isn't too bad i'll just leave it as is.</TD></TR></TABLE>
Have an alignment done.
Old Dec 4, 2005 | 10:08 AM
Default Re: (.RJ)
thats obvious but thanks.
Old Dec 4, 2005 | 10:40 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_nguyen &raquo;</TD></TR><TR><TD CLASS="quote">thats obvious</TD></TR></TABLE>
You were talking about leaving it as-is, which is not going to be a good idea unless you dont care about chewing up tires.
Old Dec 4, 2005 | 11:04 AM
GChambers's Avatar
Default Re: what rear camber kit is good for autox? (solo-x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo-x &raquo;</TD></TR><TR><TD CLASS="quote">a couple of these...
You will need to take out some of the camber to get the car to rotate. It really makes a huge difference. Thanks to Nate(solo-x) for his helpful advice.
Noah Santana
11
Jan 18, 2017 06:09 AM
NY_2_OC
Suspension & Brakes
Feb 3, 2012 09:35 PM
garyc17
Suspension & Brakes
Apr 13, 2008 08:39 AM
hatchetmansmybro
Sep 21, 2006 04:15 AM
93dx--hatch
Feb 19, 2003 10:01 AM
