My NA LS VTEC build...kinda NA
Old Dec 3, 2005 | 11:39 AM
m R g S r's Avatar
Default My NA LS VTEC build...kinda NA
b18b1 bottom end stock crank/rods
p30 pistons
gsr head
gsr cams
b16 tranny
GE ls vtec conversion kit
oem ls HG
oem gsr timing belt
oem flywheel
some kind of upgraded clutch
very mild, but its for my beater. 11.8 to 1 compression...sound decent?
plans are to spray 100 to 150 shot to fulfil my boost withdrawl needs...
Modified by m R g S r at 6:33 PM 12/4/2005
Old Dec 3, 2005 | 01:14 PM
PyroProblem's Avatar
Default Re: My NA LS VTEC build...kinda NA (m R g S r)
sweet!
That thing should eat turbos on the street. Instant torque on demand while hes waiting for boost to kick in!
What are you using to tune it?
Id be a little worried about those rods though.On a (same HP/TQ)turbo motor maybe. The torque of the nitrous would be abrupt and shocking to the rod, where as the turbo would be linear...LS rods are strong and all but dont you think thats pushin it?
what hp are you expecting to get,Id say 170 all motor and close to 300 on the bottle...
Old Dec 3, 2005 | 01:28 PM
sikciv666's Avatar
Default Re: My NA LS VTEC build...kinda NA (PyroProblem)
ha i like that <U>kind of N/A</U>.
Old Dec 3, 2005 | 02:50 PM
DIFFUT'S INC.'s Avatar
Default Re: My NA LS VTEC build...kinda NA (sikciv666)
sound good E if any thing you know where im at
Old Dec 3, 2005 | 03:34 PM
Professor15's Avatar
I would be worried to spray 100-150 shot on cast pistons especially with that compression. But give it a shot ( no pun lol) ive heard of worse, but if its tuned right with the proper fuel it may work. O and intake/headers ? /exhaust. and try to do a mild build on the head.
Old Dec 3, 2005 | 03:53 PM
m R g S r's Avatar
Default Re: (drchulo)
i dont want to put too much money into it...so unless i port the head myself im not doin much headwork. and no point in doing valves/springs and retainers because im limited by the rods (dont wanna spin bearings) and i dont want to build the bottom end....reason im doing this is because i had spare p30 pistons, just got an ls swap dirt cheap from my friend, and figured id throw on a b16 tranny.
Old Dec 3, 2005 | 03:55 PM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem &raquo;</TD></TR><TR><TD CLASS="quote">sweet!
not sure yet...probally crom (if it has nitrous controls)
and i d k about eating turbos...well...maybe....
well see if she can hang with my tegRa
Old Dec 20, 2005 | 10:40 AM
v-tec maz's Avatar
would you get more power if you use a b16 head?
Old Dec 20, 2005 | 12:28 PM
DC2 Mang's Avatar
sounds like the same build i was going to go with but instead of nitrous im going ITB now, good luck with the build
Old Dec 21, 2005 | 08:21 PM
m R g S r's Avatar
Default Re: My NA LS VTEC build...kinda NA (v-tec maz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-tec maz &raquo;</TD></TR><TR><TD CLASS="quote">would you get more power if you use a b16 head?</TD></TR></TABLE>
no....flow bench tests show that the flow is very very similar...and i bought the gsr head because the gsr camsare more aggressive than b16 cams....
Old Dec 21, 2005 | 09:04 PM
FURACERMAN's Avatar
Stock for stock, I'm a abigger fan of the GSR head for LSVs. Better chambers, cams, and "ports" for a 1.8. I just don't like the manifold situation. Good luck with the project!
Old Dec 21, 2005 | 09:08 PM
Used2beAb16's Avatar
Default Re: My NA LS VTEC build...kinda NA (FURACERMAN)
Prolly wouldnt hurt to splash some race gas in there when your spraying, and keep the timing conservative.
EgCivicSiHatch
13
Jul 5, 2009 01:17 PM
adam00
Mar 1, 2009 08:07 PM
the_big_dl86
Nov 20, 2007 10:02 AM
wfocrx
Feb 7, 2007 05:13 PM
4DRmafia
Nov 2, 2006 09:20 AM
