skunk2 manifold install. what's needed????
Old Mar 14, 2002 | 06:37 AM
rsx03's Avatar
Default skunk2 manifold install. what's needed????
guys okay I am planning to get the SKUNK2 intake manifold for my 2001 GSR.
now, I keep reading different things on this install on whats needed and what is NOT manditory..
can you please all list the specific components incl all extra smaller items I need to buy for this to work.
what are the absolute mandatory items in which I need to install this and what can i get away without doing..
thank you!
Old Mar 14, 2002 | 06:43 AM
alexboy's Avatar
Default Re: skunk2 manifold install. what's needed???? (2K1GSRBOY)
two brass t fittings, some vacuum hose, and time/patience
Old Mar 14, 2002 | 06:45 AM
alexboy's Avatar
Default Re: skunk2 manifold install. what's needed???? (alexboy)
Also soon after you may want a vtec controller to raise the gsr's crossover withe that manifold you want it to cross over at around 4800 -5000 rpm
Old Mar 14, 2002 | 06:57 AM
LS_racer's Avatar
and a new intake manifold gasket. also you may need a new throttle cable bracket. search in the recent topics for this there's some good info from about a day or two back.
Old Mar 14, 2002 | 08:53 AM
AK94GSR's Avatar
Default Re: skunk2 manifold install. what's needed???? (LS_racer)
What do you use the brass T fittings for? I haven't installed mine yet(waiting for cams), but I have never heard of people needing a Tfitting. The things I have for my install is a type r throttle cable and bracket, LS throttle pulley, and new intake manifold gasket and throttle body gasket. Oh and new injector o rings. I pretty sure that's all you need.
Old Mar 14, 2002 | 11:36 AM
rsx03's Avatar
Default Re: skunk2 manifold install. what's needed???? (AK94GSR)
k now do i need to get the specific gaskets since the openings of the SKUNK2 are larger..would I need the Type-R T/B gasket and Type-R intake manifold gasket since the ports are larger than the GSR's???
Oh and what intake would I need to use? I obviously cannot use my exsisting GSR plennum anymore correct. Last question, will be ECU be sufficient enough after this upgrade or would I need to find an ITR ECU now?
Old Mar 14, 2002 | 12:22 PM
Big Teggie's Avatar
Since your car is newer you may be able to get away with using the old manifold gasket and throttle body gasket. I did, and it is fine.
Old Mar 14, 2002 | 03:40 PM
alexboy's Avatar
you don't need the bracket just what I listed gaskets are optional i reused my old ones get some gasket sealer
Old Mar 14, 2002 | 03:43 PM
alexboy's Avatar
[QUOTE]k now do i need to get the specific gaskets since the openings of the SKUNK2 are larger..would I need the Type-R T/B gasket and Type-R intake manifold gasket since the ports are larger than the GSR's???
You dont need any other throttle body or type r gaskets.
The t fittings are to connect some radiator hoses.
If you use an itr ecu the crossover is way to high for stock gsr cams
Old Mar 14, 2002 | 04:33 PM
1fastGSR's Avatar
New User
small hands and good tools
Old Mar 14, 2002 | 06:34 PM
GSR_Hacker's Avatar
New User
ITR throttle cable
ITR throttle bracket
Zip Ties
Vaccuum hose
T-Fittings
patience
1JDMDOMINICAN
Dec 26, 2005 06:22 PM
LilCivic04
Mar 15, 2005 05:18 AM
nieva
Oct 8, 2003 04:47 PM
vtecdc2
Oct 1, 2002 09:47 PM
smkngsr
Sep 5, 2002 01:27 AM
