Got a ???????????????????????? For You
Ok, I am working on a 94 Civic Hatch with a H22 in it...
It is throwing a Water Temp Sensor code ... i have replaced the water temps sensor with a new one, and it is still throwing the code. Checked the wiring it is all good. what else could I check . Yes I have searched, but no luck....
I changed the water temp sensor on the side of the head under the dizzy...
thanks in advance...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infrontofu »</TD></TR><TR><TD CLASS="quote">
The 2-pin one? Has the air been bled out of the cooling system?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infrontofu »</TD></TR><TR><TD CLASS="quote">It has a single wire that runs to it...</TD></TR></TABLE>
That one just operates the gauge. The 2-pin sensor is the one that send the ect signal to the ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infrontofu »</TD></TR><TR><TD CLASS="quote"> I never knew that bleeding the air out of it... do i just have the car idling and open up that valve to let the air out??? </TD></TR></TABLE>
Engine off and open the bleeder screw while adding coolant. Might be your problem if you haven't done it.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infrontofu »</TD></TR><TR><TD CLASS="quote">the two pin sensor is right by the one wire that operates the gauge?</TD></TR></TABLE>
yes, replace it and then reset your ecu by pulling the hazard fuse out for 10 seconds.
kirbyman
Jan 15, 2008 06:22 PM
BrokenHatch
12
May 31, 2005 05:26 PM
