Momo Shift knobs - screws based installation any good? or will they fall off after use
Old Dec 2, 2005 | 09:31 PM
argetni aruca's Avatar
Default Momo Shift ***** - screws based installation any good? or will they fall off after use
im thinking about the momo combat evo with carbon fiber accent.
but the problem is, the installation uses a couple of screws instead of the oem style screw-in.
yay or nay?
installed on:
Old Dec 2, 2005 | 10:32 PM
Slimm-rw-'s Avatar
I'm a Jackass
Default Re: Momo Shift ***** - screws based installation any good? or will they fall off after use (argetni
I've had the horizontal screw types...don't shift hard and it MIGHT be ok, but mine fell apart within weeks
Old Dec 3, 2005 | 05:47 AM
Rory Breaker's Avatar
I had one when I first got my car.....the Momo sucked. I switched to a Levoc trigger **** that slid all the way down the shifter, great feel since you grip the shifter lower and have used it ever since.
Old Dec 3, 2005 | 05:57 AM
Nataku's Avatar
where to find this one?
Old Dec 3, 2005 | 07:01 AM
Kendall's Avatar
My ITR came with one when I bought it and the screws did little more than damage the threads on the shifter.
Old Dec 3, 2005 | 07:06 AM
Cliffjumper2's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote"> screws did little more than damage the threads on the shifter.</TD></TR></TABLE>
yep, and the **** never felt snug.
Old Dec 3, 2005 | 08:51 AM
GSR95DXHATCH92's Avatar
I have the same shift **** on my car the best thing to do is find out exactly where you want your **** to sit and drill a pilot hole (not all the way thru your shifter!!!!) this is for the set screws to set in place then you never have to worrie about it moving shift as hard as you can! Have fun
Old Dec 3, 2005 | 10:28 AM
beaterman's Avatar
no get one that screws on the the threads. you will like it much better and it will always be tight.
Old Dec 3, 2005 | 05:20 PM
Default Re: (GSR95DXHATCH92)
good idea, but then wouldn't that weaken the shift lever
Old Dec 3, 2005 | 06:06 PM
Racermech's Avatar
Default Re: (Cliffjumper2)
I had a momo for years, it had 3 set screws. I worked fin. SOmetimes it would come loose, but i allways had the allen key with me so i could tighten it back up. I would say about every 6monthes i had to tighten it. Mine sat low enough that the set screws did not hurt the threads
Old Dec 3, 2005 | 06:19 PM
The Droogan Leader's Avatar
Now with ultra-violence!
Default Re: (Racermech)
I'd give that shifter a "nay". It just wouldn't look right for some reason, even with the carbon fiber pieces.
Old Dec 3, 2005 | 06:55 PM
loudassVTEC's Avatar
Default Re: (Shin-tegra)
I got the 440gram Skunk2 ****. That **** is great! Never comes loose, and makes the shift feel great, do to its extreme heavyness. Not to mention it looks great, and feels great in your hand.
Old Dec 4, 2005 | 06:32 AM
Default Re: (loudassVTEC)
most screw on ***** will fit nicely on the teg, just make sure it deosn't have the plastic piece for the threads because they tend to crack if you screw it on too low or too tightly.
shawnxme
Nov 20, 2007 05:13 PM
norcalbayboy
Jun 4, 2007 11:41 PM
keeganl
Feb 28, 2007 05:44 AM
Joey.
Jan 24, 2007 06:45 AM
foolintherain617
Oct 27, 2004 04:35 PM
