problem with Skunk 2 IM on a gsr
Old Dec 2, 2005 | 09:22 PM
racekar711's Avatar
Default problem with Skunk 2 IM on a gsr
I read the write ups on this setup and not sure why its not working.
to get a skunk2 IM to work on a gsr youre suppose to get the ITR throttle cable and bracket and non gsr TB pulley
I had maxbore modify my stock TB pulley so that it should work with this setup but my throttle cable is too tight and opens the throttle plate making my car rev at 5,000 rpm. Thats with the throttle cable all the way loose?
anyone else run into this problem?
im using my stock gsr tb but i had my tb pulley modded to work with the skunk2 setup but the cable is too tight causing high rpm at idle
so now i have to buy another TB pulley.
what car models can i get them from? anyone have one
Modified by racekar711 at 11:23 PM 12/2/2005
Modified by racekar711 at 12:27 PM 12/3/2005
Old Dec 2, 2005 | 10:09 PM
94inteGSR's Avatar
Default Re: problem with Skunk 2 IM on a gsr (racekar711)
u can actually use gsr throttle body.. i used it and it was fine.. but only get that mannifold if u gonna get bigger cams and chipped ecu other wise ur gonna lose power
Old Dec 3, 2005 | 06:14 AM
racekar711's Avatar
still looking for one need it quick
Old Dec 3, 2005 | 11:27 AM
racekar711's Avatar
uppppppppppp
Old Dec 3, 2005 | 11:46 AM
racekar711's Avatar
uppppppppppppppp
Old Dec 3, 2005 | 11:49 AM
Comp97GSR's Avatar
Default Re: (racekar711)
If you are seriouslly looking for the right answer, you need to post a pic. From what you are saying, you need to get a throttle cable from an ITR, maybe one from a GS would work.
Post a pic.
Old Dec 3, 2005 | 03:58 PM
94DOHCGsr's Avatar
On the HOW TO INSTALL BLOX IM by Honda Hick (I think) he said to use a tb pulley off the ls.
I heard that the stock tb and cable will work just that it wont be as clean and you probably have to jerry rig it.
hitekper4mance
Northern California (Sales)
May 23, 2007 02:54 PM
krucial7integra
Jan 11, 2007 12:31 PM
vtec25
Jun 13, 2006 02:29 PM
jdm7
Oct 30, 2003 09:17 AM
