Suspension & Brakes Theory, alignment, spring rates....
Alignment settings
Old Dec 2, 2005 | 07:14 PM
.E's Avatar
.E
Default Alignment settings
Went to get an alignment today in preparation for an upcoming track day.
Results when completed were:
Front:
L: R:
caster: +0.72 +0.04
camber: +0.72 -2.08
toe: +0.01 +0.01
total toe: +0.02
Rear:
L: R:
camber: +0.16 -0.48
toe: +0.08 +0.08
total toe: +0.16
thrust angle: 0.00
Question is should I be worried about the positive camber on the left side?
Vehicle is a 95 Civic HB; lowered about 2.5"
Old Dec 3, 2005 | 07:15 AM
Kendall's Avatar
I'm not too sure about those settings. I would definately try and get the camber at least close, and get the rear toe resituated to be closer to 0.
Old Dec 3, 2005 | 09:50 AM
.E's Avatar
.E
Default Re: (Kendall)
Thanks, I appreciate the reply. Is there any recommend camber setting I should try and camber kit that will bring it mores towards the negative?
Old Dec 3, 2005 | 12:15 PM
bad-monkey's Avatar
Default Re: Alignment settings (.E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .E &raquo;</TD></TR><TR><TD CLASS="quote">Went to get an alignment today in preparation for an upcoming track day.
Front:
L: R:
caster: +0.72 +0.04
camber: +0.72 -2.08
toe: +0.01 +0.01
total toe: +0.02
Rear:
L: R:
camber: +0.16 -0.48
toe: +0.08 +0.08
total toe: +0.16
thrust angle: 0.00
Vehicle is a 95 Civic HB; lowered about 2.5"</TD></TR></TABLE>
the + camber will suck on track. u want at least -1.25 degrees of camber up front. i think closer to 2 is probably better. it also looks like something is bent.
Old Dec 4, 2005 | 08:34 PM
.E's Avatar
.E
Default Re: Alignment settings (bad-monkey)
Checked for bent components and the UCA & LCA look fine, but the knuckle seems possibly bent.
Thanks for your help and advice.
bopbop93030
Suspension & Brakes
Apr 8, 2008 04:08 PM
sk8shorty012
23
Nov 14, 2006 10:59 AM
ahs2m2
Suspension & Brakes
Jun 6, 2005 12:02 AM
austrian type-R
Jul 23, 2003 07:42 AM
darkknightwong
11
Sep 18, 2002 09:41 AM
