What did you do to your EF today?
Old Dec 2, 2005 | 04:59 PM
CRXB16T's Avatar
Default What did you do to your EF today?
Update:
-Installed Foglights (Did some research on H-T, and decided to go with autozone "blazer foglights"
-Painted headlights yellow (some people like it some hate it. Personally I didn't notice that much of a reduction of light output. I works well in bad weather, reduces glare to oncoming traffic. One can of paint thinner and it will come right off if I change my mind.
-Installed a neon half rad, 12" pro form slim fan.
-Then put stock radiator back in until I can get the rad cap from JC whiney.
-Installed MSD Pro Cap, and Blaster 2 coil it is mounted near the fuel filter, but I want to relocate to a better hidden area to keep the wire tuck looking clean.
-My friend finished welding the seat brackets so i could install my Recaros (i need to use washers or something to get them level.
-Relocated most of the engine harness connections to inside the car behind the console.
-Finished the keyless door handle mod, and installed power door locks.
-Painted my BMW Bottlecaps Gloss black
-Went back to full exhaust and ditched the side exit. I miss shooting flames
-Test fitted my 4 point cam-lock harnesses, need to weld in a harness bar before I hook them up.
Modified by CRXB16T at 5:08 PM 1/9/2006
Old Dec 2, 2005 | 05:01 PM
88 rex's Avatar
Default Re: What did you do to your EF today? (CRXB16T)
Messed with my timing, fixed some anti-theft wiring , and spent endless hours online researching my future projects for my rex.
Old Dec 2, 2005 | 05:14 PM
cmyrex's Avatar
looked for parts on me ef hope that counts
Old Dec 2, 2005 | 05:15 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: What did you do to your EF today? (88 rex)
Didn't even see mine
mattie_96's Avatar
revved past 7600 and beat a moded lancer ralli art.....hahha...light EF's rule
Old Dec 2, 2005 | 05:25 PM
solfly's Avatar
Default Re: (mattie_96)
reved hard broke loose in second third and carved corners
Old Dec 2, 2005 | 05:26 PM
Pee Wee's Avatar
changed brakes on all four corners and then had some boosted highway fun
Old Dec 2, 2005 | 05:39 PM
Chase's Avatar
Default Re: (EF8opey)
put my freshly steamclean'ed and restored carpet back in. Put my ST 22mm swaybar endlinks back on. Ordered some oh so badass stuff for my car
Old Dec 2, 2005 | 05:58 PM
Stunna MIKE's Avatar
Fully detailed my car. Put in a short shifter. Rotated And balanced my tires. uhh.. put my liscense plate back on... and attempted to put on my fog lights but got tired
Old Dec 2, 2005 | 06:05 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (Aaron EF9)
i went to work to pay for future mods. and rent. and school.
Old Dec 2, 2005 | 06:10 PM
del_barry's Avatar
Default Re: (sanimalp)
replaced my cluster bulbs and got some chinese food
Old Dec 2, 2005 | 06:11 PM
LoSt is BlaCk's Avatar
threw some stocks in the backseat to trade...ef=moving van
Old Dec 2, 2005 | 06:14 PM
FOMULA91's Avatar
Default Re: (LoSt is BlaCk)
Installed a new window wiper.
Old Dec 2, 2005 | 06:17 PM
Default Re: (FOMULA91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 &raquo;</TD></TR><TR><TD CLASS="quote">Installed a new window wiper.</TD></TR></TABLE>
I need some new wiper blades too. Haha
Old Dec 2, 2005 | 06:19 PM
SlobberGoat's Avatar
Which one?
In one I'm still chipping sound deadner.
Another needs its rego stickers swapped.
The third needs an oil change today.
Old Dec 2, 2005 | 06:24 PM
jdmazm's Avatar
Default Re: (SlobberGoat)
first of all, great thread.
opened my door panel to fix my lock
new center console installed
new cig tray and liter for my phone
put some radials on
chirped 4 gears and pissed on a ricer.
Old Dec 2, 2005 | 06:26 PM
Default Re: (jdmazm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmazm &raquo;</TD></TR><TR><TD CLASS="quote">first of all, great thread.
chirped 4 gears and pissed on a ricer.</TD></TR></TABLE>
Haha, Cheers
Old Dec 2, 2005 | 06:48 PM
eda6's Avatar
reset my car alarm because some bitch hit my car with her door and left a dent.
Modified by eda6 at 10:58 PM 12/2/2005
Old Dec 2, 2005 | 06:56 PM
DUCeyez97's Avatar
Default Re: (eda6)
Bought some new H&R springs, haven't put them in yet though.
Old Dec 2, 2005 | 06:58 PM
drew2's Avatar
Default Re: (eda6)
put a new headunit in my car, sound out of both speakers finally!
then my check engine light came on and the car wouldn't rev past 3k (no ecu codes tho)
then after i shut it off it wont crank at all, even w/ a jump
now im sitting on my *** trying to figure out what just happened
Old Dec 2, 2005 | 07:03 PM
Riceboy891's Avatar
Default Re: (drew2)
I got mine running again today!!!!! (deer accident)
Old Dec 2, 2005 | 07:28 PM
daidilus's Avatar
Default Re: (Riceboy891)
installed B16A head with GSR cams on a B18A block and got it to run, still have to fix the leaky hose, wire vtec and change the ECU...not my car though...just working on it for a customer!!!
Old Dec 2, 2005 | 07:43 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (daidilus)
what radiator is that ^^?? looks.. different..
T3k C's Avatar
Nice, as for me i tried to drop the back of my car and broke the lower arm control bolt on both SIDE!!!
Old Dec 2, 2005 | 07:44 PM
CRX Toad's Avatar
Cut it into 6 equal pieces and threw it away. (finished off the CRXster)
