What Exhaust Setup are you running(EG's w/ B18c1)??
Old Dec 2, 2005 | 02:55 PM
Touch's Avatar
Default What Exhaust Setup are you running(EG's w/ B18c1)??
Want to do RSR mag exhaust, but not sure about the right header/ cat combo for my EG.
Please post your setups and how you like them.
Header:
Cat/ Test pipe:
Catback:
Canister/ Muffler:
Thanks folks
Old Dec 3, 2005 | 07:39 AM
Touch's Avatar
Default Re: What Exhaust Setup are you running(EG's w/ B18c1)?? (Touch)
bump
Old Dec 3, 2005 | 07:17 PM
Touch's Avatar
no response?
Old Dec 4, 2005 | 07:25 AM
HCarPhreak's Avatar
I have a JDM B18C in my 92 CX hatch. The exhaust setup I'm running is a JDM OEM TypeR 4-1 header (I love the way it looks like a stock exhaust manifold, but has a 2.5" collector), 2.5" Carsound high flow cat, and A'Pexi N1 cat-back exhaust. I'm really happy with this setup and it has good pull up top. My only issue is that since the header is longer than normal itpushes everything back. It actually caused the exhaust to rattle against one of the heatshields on occasion. This was remedied by bending the heat shield back. I think next time I replace the cat (Carsound high flows only seem to last about two years), I'm going to go with a shorter cat. I got my current cat from IPS Racing, but maybe it was designed for a different length header or maybe the integra setup is a little longer, I don't know. Hope this helps.
Mike
Old Dec 4, 2005 | 02:21 PM
Touch's Avatar
Default Re: What Exhaust Setup are you running(EG's w/ B18c1)?? (HCarPhreak)
thanks mike, it does... anybody else. my main concern is a clean fit and smog in CA, since I will be moving there.
Old Dec 5, 2005 | 04:19 AM
Touch's Avatar
c'mon. nobody else has a solution?
KeithDigital
22
Mar 7, 2010 04:08 PM
posHonda
Feb 16, 2008 01:00 PM
Qwikrex
Feb 16, 2003 03:15 PM
civic_sir94
Nov 29, 2001 08:59 PM
