lean it out?
Old Dec 2, 2005 | 01:27 PM
EF8IGHT's Avatar
Default lean it out?
hey i have a pr3 ecu with a mugen like program on it. i know these programs run considerably richer than stock. this is the reason im having trouble passing emissions. so i bought an s-afc and i need to know how much fuel to take out so my motor doesnt got POP!
please help me
my emissions test results were
CO. limit 20.00 my test 51.07
thas also running woth out a cat please help
Old Dec 2, 2005 | 01:59 PM
zccr-xsi's Avatar
glad to be in FL. no test here i run without a cat too.
Old Dec 2, 2005 | 02:17 PM
EF8IGHT's Avatar
Default Re: (vteckillenzc)
wow that didnt kelp me at all
Old Dec 2, 2005 | 02:44 PM
Crx Jimmy's Avatar
Default Re: lean it out? (EF8IGHT)
lean it out with a adjustable FPR
Old Dec 2, 2005 | 02:58 PM
EF8IGHT's Avatar
Default Re: lean it out? (Crx Jimmy)
DOES ANY ONE READ?
i already have the afc on the car thats what i want information on
not how great it is to not have to pass emissions
not othere setups i <u>could</u> use( i know there are pleanty)
but how lean to set my afc to pass emissions
if you dont know dont waste my time
Old Dec 2, 2005 | 03:03 PM
Crx Jimmy's Avatar
just lean it to hell the test is what 60 seconds i dont think it will blow in such a short time, every motor is going to be different so someone cant tell you how much to lean YOUR motor, especially with some unkown hack program running it, why dont you just get a stock ECU, it will pass fine, or buy a wideband O2 if you are worried about blowing your motor. read the instructions on the box for the afc, there is no way to tell how lean you are without a wideband or dyno
Old Dec 2, 2005 | 04:07 PM
suspendedHatch's Avatar
Take it to a dyno and spend what, $100 to get it tuned? You'll get better driveability, more power, mileage, and you'll be able to pass emissions. Otherwise all that **** on your car is just getting wasted.
Old Dec 2, 2005 | 05:16 PM
ED7's Avatar
ED7
Default Re: lean it out? (suspendedHatch)
Well you will never pass without a catalytic converter..so thats your first priority. Then on the afc i would go about -5 about. Maybe try up to -10. It will also advance the timing so be careful. You might want to retard the base timing a couple degrees.
Old Dec 2, 2005 | 10:12 PM
EF8IGHT's Avatar
Default Re: lean it out? (ED7)
ok i will try that thanks
Old Dec 2, 2005 | 10:16 PM
ludesrv's Avatar
Put a cat on....tune your car....go get e-test.
Old Dec 3, 2005 | 12:05 PM
EF8IGHT's Avatar
Default Re: (ludesrv)
i have a cat im was going to put it on the whole time i found a stock ecu for the time being so i just going to plug that up and say expletive the safc
EJ8 GSR-T
Dec 11, 2006 05:05 PM
Sandmaggot
Jul 28, 2006 08:21 PM
Otherguy
Jun 27, 2005 12:37 PM
FourthGenHatch
Apr 19, 2004 05:55 PM
SimbaDogg
Jul 2, 2003 09:17 AM
