Window Trim problem
ok so above my morror on the incline of the window trim it has been scrunched up and gives an annoying air leak noise from the outside.
if i get a new window trim, how hard will it be for me to install a new one and what tools would i need?
i am getting a Helms manual for xmas does it address this problem?
its pretty easy. i lowered the window, took the black plastic piece off thats is on top of the rubber near the door jamb, and yanked the rubber piece off. to install it i removed the mirror and door panel (dont have to but it makes it a lot easier). i used a lot of lube to guide the new rubber piece back in place. it should slide right in with. use lube it will help a lot. whole thing took like 30 minutes to do. no more air leak for me!!!!
