ground noise
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swfitz2003 »</TD></TR><TR><TD CLASS="quote">just installed full msd ignition and ground wire kit on a 94 civic d16. now i have bad ground noise through my radio, any ideas??</TD></TR></TABLE>
do you have any amps in the back of the car?
ground noise comes from grounds that attach to the chassis at different points. The more power being grounded out at different points, the worse the feedback will be. If you could ground everything on your car to one point, you will not have feedback. Try running the ignition amp ground through the firewall, and ground it where your ground kit is.
Integra99GSR
Audio / Security / Video
10
Sep 10, 2003 11:56 PM
