Suspension setups on REXs PICS
Ok well I did some searching and could not find too much.
So lets see your suspension setups PICS PLEASE
and so everyone is on the same page and we have a smooth thread
list
SPRINGS:
SHOCKS:
WHEELS AND TIRE SIZE:
EXTRAS:
Pics of my 2G pile
SPRINGS: Cut stockies form what I see
SHOCKS: Blown stockies
WHEELS AND TIRE SIZE: LS Wheels 15s
EXTRAS: Lots of bounce and sqeaks, reason nfor this thread
list
SPRINGS:
SHOCKS:
EXTRAS:
Pics of my 2G pile
Ground Control Coilovers
Springs: Eibach Sportlines 425f/600r
Shocks: Koni Yellow Adjustables
Wheels & Tire Size:
GSR wheels Polished
185/60/14 42MM Offset
BMW Bottlecaps now painted gloss black
195/60/14 35MM Offset
Sway Bars: HF Front & SI Rear Sway Bar
Extras:
Front Strut Tower Bar
Odyssey Drycell 13lb Battery
Future Plans:
Harness Bar on B pillar with 4 point camlock harnesses
Camber Kit
Lower Tie Bars
Rear Strut Tower bar
ITR LCAs
Poly bushing kit
Wheels & Tire Size:
GSR wheels Polished
Extras:
Future Plans:
Camber Kit
Lower Tie Bars
ITR LCAs
Poly bushing kit
Thread kinda turns useless once someone on coilovers rolls by...
But I'll chip in. (In all pics coilovers are in just abou tthe ssame trim. Give or take a quarter of an inch)
Koni Yellow adjustables
Skunk2 coilovers
15" 6,5J ET43 MAK spirit
195/50/R15 Toyo Proxes T1-S
Koni Yellow
H&R Sport springs
15" 6,5J ET38 MIM Cup (porsche boxter clones)
195/50/R15 cheapass tires
Koni Yellow
Skunk2 coilovers
15" 6,5J ET40 (turned from 38) Speedline Safari (My winter wheels)
195/40/R15 Uniroyal rainsport (too skinny tire, doesn't work good, and speedo was off)
Same setup, same wheels, same car, different tires
195/50/R15 Kumho KW17 winter sports
Koni Yellow
Skunk2 coilovers
16" 7J ET45 Rota Slipstream
215/45/R16 Falken Azenis RT-215
Extra's:
OMP top strut braces front+rear
Suspension techniques rear swaybar.
Ebay lower braces
ES hyperflex kit
Overall impressions:
The koni's work really nice with the skunk2's. They are however incredibly stiff and low speed bump is awfully harsh. They're meant to be driven hard, and that's when you finally see the point in them. I really want toe GC top-hats DRIVEN is selling tho. I'm so low I keep hitting the bump stops.
As a summer tire I liked the toyo's alot. Granted, they wear out real fast, and they don't stick like my azenis... but they're cheap as **** wich doesn't make me feel as bad when I'm abusing theshit out of em.
The 15" toyo's do roll alot on the sides, that's why I have the 16" falkens. In retrospect, I think the 15" falkens would have worked fine too. And I think the 16"s are just a tad too big.
The 15" uniroyals were nice in the rain, but their odd size threw off my speedo. Also made the car scrape the pavement here and there. The 50's are alot better. I like the kumho's as well.
Skunk2 coilovers
Koni Yellow
H&R Sport springs
Koni Yellow
Skunk2 coilovers
Koni Yellow
Skunk2 coilovers
Extra's:
Ebay lower braces
ES hyperflex kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex »</TD></TR><TR><TD CLASS="quote">CRXB16, Which length springs did you get and how do you like those rates?
thanks
Not sure of the lengths, but I like the rates. They are a really stiff for the street, but I don't mind because I do alot of "spirited" driving. Autozone gave me a bad remaned axle so it vibrates around right turns really bad, and the car needs wheel bearings and an alignment. So i havn't been able to test out this suspension setup in my crx. Not sure what it will do at its limit now that this car has a quaife.
When I had this setup in my hatch with no sway bars it was very tailhappy. Overall im content with my setup now, but im not done. Still have more tuning and parts to get.
thanks
</TD></TR></TABLE>Not sure of the lengths, but I like the rates. They are a really stiff for the street, but I don't mind because I do alot of "spirited" driving. Autozone gave me a bad remaned axle so it vibrates around right turns really bad, and the car needs wheel bearings and an alignment. So i havn't been able to test out this suspension setup in my crx. Not sure what it will do at its limit now that this car has a quaife.
I'll play... although this is becoming a picture thread.
SPRINGS: ERS 400F/500R; 2.5ID; 7" Free length;; GCs
SHOCKS: Koni SPSS Fronts; Koni Yellow Rears
WHEELS AND TIRE SIZE: 15x6.5, 15x7; 205/50-15
EXTRAS: Stock SI Front Sway; ST Rear; Neuspeed Rear Lower Tie Brace; ES Bushings; Custom extended top hats for rear shocks
SETI20, That was pretty informative. I like the pics. I have been carefull about slip on coilovers cause of complains they do not go low enough. But your car loks great
shitty tokiko blues
ground controls
15in rota C8's
nitto 450 extremes 205/50/15
my current setup for the winter is the stock si wheels, on falken ziex
this spring i plan on either getting koni yellows with the gc top hats, or just going with the PIC full coilover setup not sure yet
ground controls
15in rota C8's
My suspension setup on my project:
Tokico Blues
Skunk2 slip on coilovers
Suspension Techniques 22mm solid rear sway bar
23 mm hollow DA front sway bar with Energy Suspension bushings and endlinks
Skunk2 front and rear upper strut bars
Skunk2 rear lower tie bar
15" LS meshies with 195 50R 15 Falken Ziex tires.
Tokico Blues
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 »</TD></TR><TR><TD CLASS="quote">
JDM Front, With clear sidemarkers?
LOL
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aaron EF9 »</TD></TR><TR><TD CLASS="quote">JDM Front, With clear sidemarkers?
LOL
nm lol
Modified by Stefndogg at 1:36 AM 12/3/2005
LOL
</TD></TR></TABLE>nm lol
You've all seen it before:
Springs: Ground Control coilovers (any height) - 400f/450r
Dampers: Koni Yellows all around
Bars: HF front bar, ST rear bar
Wheels: Enkei RPF1s (15x7)
2005 SCCA Southwest Div SoloII points champion
Its a tiny bit lower than that now...about .25"
Tokico Blues with Tom's Motorsport Coilovers
Neuspeed front strut tower bar
American Racing Vortech's 16"x7.5" with Federal 595 205/45/R16
I'd put pics but I went over my bandwidth for photobucket. Sorry
LOL
EDM.........not JDM
LOL
</TD></TR></TABLE>EDM.........not JDM
Tockio blues
Neuspeed sports 2" F 1.8" R
tires dunlop sp8000 195/55-14
Just ordered some Neuspeed /koni SP3's we'll see how those are in a few weeks.
Also all poly bushings around and new UCA's, lower ball joints, Tierods, and wheel bearings. Also neuspeed Strut brace, jimfab x-member. Time to whor eout more pics
-James-
-James-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex »</TD></TR><TR><TD CLASS="quote">EDM.........not JDM
Sry
</TD></TR></TABLE>Sry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">B+G coilovers, on 500lb springs all around/
nice...i have been interested in those..how are they?
</TD></TR></TABLE>nice...i have been interested in those..how are they?
LOL
n00b
LOL
</TD></TR></TABLE>n00b
on the fender not the lights next to the headlights.
