OK i NEED HELP PLZ I HAVE A Chaeck engine light that wont go off
Old Dec 1, 2005 | 11:40 PM
dc4rider's Avatar
Default cel will not go off
ok the cel wont go off and it wont let me pull codes out hella ppl told me to cheack the dizzy but didnt fix it relays all new im stuck plz help me out and the ecu is good
Modified by src-rider at 1:06 AM 12/2/2005
Old Dec 2, 2005 | 02:40 AM
blkhatch92's Avatar
year make and model?
Old Dec 2, 2005 | 02:41 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (blkhatch92)
How will it NOT pull codes? Can you be a little more descriptive here?
Old Dec 2, 2005 | 03:01 AM
blkhatch92's Avatar
no joke . . .noticed anything wierd about how your ride runs? anything different?
Old Dec 2, 2005 | 04:06 AM
Quick99Si's Avatar
Default Re: cel will not go off (src-rider)
Maybe you're confusing the "inability to pull codes" with a bad ECU. Have you tried another ECU?
Adi
Old Dec 2, 2005 | 04:38 AM
91civicDXdude's Avatar
if the check engine light is on, you can "pull codes" if not, you're not doing it right.
Old Dec 2, 2005 | 02:43 PM
dc4rider's Avatar
Default Re: (91civicDXdude)
i use a p28 cel still on i jump the plug still on i know how to pull codes dun it hella times but this car wont let me pull codes it gets no gas or spark the car is a 92 civc hb dx i cheack the grounds clean it and everything /the cel stays on and will not let you pull codes /thats y im askin you guys for help /i got a guy that works for the honda delaership to look at it and he cant fine the problem /help me
Old Dec 2, 2005 | 02:46 PM
dc4rider's Avatar
Default Re: (src-rider)
befor it die on me i hit a bump then it bog down and die
Old Dec 2, 2005 | 02:49 PM
impact_blu's Avatar
try a different ecu, has your ecu wires been hacked? Could be a loose wire, happened to me..
Archidictus's Avatar
Unceasing Measure
It gets no gas and it gets no spark but you're sure the relays are fine? If the main relay is bad you won't get either of those things. If the ECU is damaged there's a possibility that you won't be able to get those things either. Have you checked all of your fuses and such? I know it seems simple, but sometimes it's the simple things that keep your car from working.
Old Dec 2, 2005 | 03:00 PM
dc4rider's Avatar
I just try to use the p72 and i jump the plug it still want let me pull code
Old Dec 2, 2005 | 03:05 PM
dc4rider's Avatar
all new fuse i cheack it like 3 4 time i put in a new relay on the driver side by the clutch pedal /i allso tryed new wireinharness didnt fix it i and so stuck on stuip right now
Old Dec 2, 2005 | 03:37 PM
dc4rider's Avatar
and you know how win you start your car cel is supose to turn off for like a sec /it dont do nothing/it just stay on
Old Dec 2, 2005 | 03:42 PM
Unceasing Measure
1.) how do you know you're not getting spark?
2.) how do you know you're not getting fuel?
3.) how did you check your distributor coil and ignition switch?
Old Dec 2, 2005 | 07:37 PM
dc4rider's Avatar
Default Re: (Archidictus)
volt meter for the dizzy and a nodlight for the injecter got it from snap on it shows you the on and off time of the injecter
Old Dec 3, 2005 | 01:00 AM
dc4rider's Avatar
help
89eFRACER
12
Apr 13, 2006 09:21 PM
Spoolin'VW
15
Nov 19, 2005 03:27 PM
RexB16
Jun 3, 2005 10:33 AM
null.
10
Jul 2, 2004 05:55 PM
nek0
Jul 9, 2003 04:49 PM
