b18c1
Old Dec 1, 2005 | 07:20 PM
OH_SNAP10k_SHIFT!'s Avatar
Default b18c1
okay i did my research. i want to bore my block to 84mm and run NA. and have about 12:1 CR. question is, whats a good brand sleeve? pistons? also, do i have to bore out my head also? coz i figured u bore out the block, do u have to "bore-match" the head? kinda lost on this part. and also a place for me to get good deals on these parts. thanks.
Old Dec 1, 2005 | 08:39 PM
94DOHCGsr's Avatar
Default Re: b18c1 (OH_SNAP10k_SHIFT!)
Why dont you just run some ctr pistons with a thicker head gasket? Cheaper. But if you want to bore out the block i would go with either JE or wiseco pistons.
Instead of "Bore" out the head, i think you are trying to say port it and polish it. Most machining places can do this for you.
Are you going to do the build yourself???? If you arent, then it will cost a pretty penny.
Old Dec 1, 2005 | 08:52 PM
onepoint6i's Avatar
Default Re: b18c1 (94DOHCGsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94DOHCGsr &raquo;</TD></TR><TR><TD CLASS="quote">
No, he means bore the combustion chamber to meet the bore of the cylinder..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OH_SNAP10k_SHIFT! &raquo;</TD></TR><TR><TD CLASS="quote">okay i did my research. i want to bore my block to 84mm and run NA. and have about 12:1 CR. question is, whats a good brand sleeve? pistons? also, do i have to bore out my head also? coz i figured u bore out the block, do u have to "bore-match" the head? kinda lost on this part. and also a place for me to get good deals on these parts. thanks.</TD></TR></TABLE>
Some piston designs you may have to bore the head out, some you dont...I think it depends on the dome size etc...
The choice of piston depends on how much your willing to spend and what your really looking into as far as compression piston material,weight of the piston(the lighter the more expensive etc), it's all a matter of preference..Usually you go with something your engine builder rec's for your setup...If you're building it yourself then I would just search ALOT..it will help you come to a conclusion..
There are many good sleeving machine shops out there like Golden Eagle,AEBS...the list goes on and on... Heres a thread on some members preferences: https://honda-tech.com/zerothread?id=795869
Old Dec 2, 2005 | 05:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94DOHCGsr &raquo;</TD></TR><TR><TD CLASS="quote">Why dont you just run some ctr pistons with a thicker head gasket? Cheaper. But if you want to bore out the block i would go with either JE or wiseco pistons.
Are you going to do the build yourself???? If you arent, then it will cost a pretty penny.</TD></TR></TABLE>
i dont want ctr pistons... i wanna bore it out and get close to a 2.0l. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">
There are many good sleeving machine shops out there like Golden Eagle,AEBS...the list goes on and on... Heres a thread on some members preferences: https://honda-tech.com/zerothread?id=795869</TD></TR></TABLE>
yup ur right. i mean bore out the combustion chamber to match the block bore. so do i have to do that? coz i know if i over bored my block to fit .25mm oversized pistons i can get away without doing anything to my head. am i right? correct me if im wrong anyone. thanks
Old Dec 2, 2005 | 12:26 PM
onepoint6i's Avatar
yup ur right. i mean bore out the combustion chamber to match the block bore. so do i have to do that? coz i know if i over bored my block to fit .25mm oversized pistons i can get away without doing anything to my head. am i right? correct me if im wrong anyone. thanks</TD></TR></TABLE>
i already answered your question.....
Certain piston designs with the same size you may have to bore the head out, others you dont...
:I had a set of 84.5MM JE pistons that i sold, on those the domes would sit well within the 81mm bore on the head, In other words i could have used them with my 81MM combustion chamber..no boring was required...get my drift?
Old Dec 2, 2005 | 02:42 PM
Default Re: b18c1 (onepoint6i)
:I had a set of 84.5MM JE pistons that i sold, on those the domes would sit well within the 81mm bore on the head, In other words i could have used them with my 81MM combustion chamber..no boring was required...get my drift? </TD></TR></TABLE>
oops. i wasnt reading it correctly. yup. got it thanks. so what gasket did u have to use? im assuming 84.5mm and by the way, what was ur CR for ur setup? did u have a b16, itr or gsr head? thanks in advance.
Old Dec 2, 2005 | 03:22 PM
onepoint6i's Avatar
no i never used the pistons..but it was suppose to be 11.5:1 with a B16 head on a LS crank i believe i forgot, its been a long time since i had those...
but yeah check the JE web site you should find those in there...
Old Dec 2, 2005 | 06:50 PM
onepoint6i
fergy016
Jul 7, 2007 08:27 PM
ITRnorway
Nov 16, 2006 01:54 PM
DB2#308
May 17, 2004 11:54 PM
JDMvtecDRAGSTA
Apr 10, 2004 05:05 PM
turboex
Nov 11, 2002 11:43 AM
