1990 doors on a 1989
Old Dec 1, 2005 | 03:58 PM
PIMPALA-SS's Avatar
Default 1990 doors on a 1989
i have some doors from my 1990 Si (seatbelts on the doors)
and a buddy has a 1989 hatch, (seatbelts on the pillar)
other than the obvious, having to remove the pillar seatbelts, and possibly hookup the 1990 seat belt buckles off the floor, will they "bolt up"??
i've done a LOT of **** to hatches.. but this is a new one to me.
and yes, i searched.
Old Dec 1, 2005 | 04:13 PM
si0385.'s Avatar
Default Re: 1990 doors on a 1989 (PIMPALA-SS)
i wanna know too... bump
Old Dec 1, 2005 | 04:39 PM
Tyson's Avatar
Default Re: 1990 doors on a 1989 (jaydeum4lyfe)
88 - pillar mounted
90-91 - door mounted
89 - depends
88 doors fit on 90-91 chassis.
90-91 doors do NOT fit on 88 chassis.
its due to the thickness of the doors, and the door jams fit to accomodate the extra thick doors, even without the seat belt mechanism bolted to the door.
and besides, changing from door to pillar mounted seat belts is not a trivial task.
Old Dec 1, 2005 | 07:44 PM
PIMPALA-SS's Avatar
Default Re: 1990 doors on a 1989 (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">88 - pillar mounted
89 - depends
and besides, changing from door to pillar mounted seat belts is not a trivial task.</TD></TR></TABLE>
well.. if the doors themselves did fit, then i dont see why changinf from door to pillar mounted belts would be hard, seeing how the car they would go on already has pillar mounted belts.. so simply removing the belt mechanism off of the door, and still using the pillar belts would be the answer..
but if the 1990 doors wont go on a 1989 with pillar belts, then thanks for answering my question.
Old Dec 3, 2005 | 07:24 AM
PIMPALA-SS's Avatar
89 - depends
thanks for trying to help, but i talked to 3 people on other forums that have actually done the swap, and they all say with very little work, and effort, they bolt right on, and its not a problem!
Old Dec 3, 2005 | 09:45 AM
cvcrcer's Avatar
I should do this too. You know that they didn't have side impact door beams until 1990.
Dave K.
Jan 9, 2017 05:07 AM
Ldo
21
Apr 19, 2014 07:39 PM
Rywire
13
Jun 13, 2006 09:06 AM
streetlegal gocart
10
Dec 2, 2004 11:50 AM
chhuong
Nov 12, 2002 11:55 AM
