Anyone running on Eibach Sportlines....
Old Dec 1, 2005 | 02:30 PM
MansuDC2's Avatar
Default Anyone running on Eibach Sportlines....
Hi, i was wondering if anyone here on HT is running on a set of Eibach Sportline Springs w/ stock struts or aftermarket. Just wanted to know if you guys are could you post your pics of your ride I kinda of want to see how they look on 3rd gen tegs, I want to switch from Skunk2 coilover sleeves to a set height spring for a more better ride. Please post your pics. I want to see if they would look the same as the height I have my coilover sleeves set at. I'm running on 16x7 Slips w/ 205/45ZR16 tires wonder if it would look good with a drop of 1.8".
Glenn
Old Dec 1, 2005 | 06:44 PM
dc2nick's Avatar
Default Re: Anyone running on Eibach Sportlines.... (MansuDC2)
This would be where i come in....
Eibach Sportlines (springs are for sale actually) W/ KYB AGX Gas shocks and 15" Rota Circuit 8's.
Message me if ur interested in the springs.
Old Dec 1, 2005 | 07:09 PM
dc2nick's Avatar
they do make the front look a little bit higher.
but they handle AMAZING, providing you have goot tires to go along w/ them.
dont judge them if you dont know. I take turns at rediculous speeds and the back end wont budge.
Old Dec 1, 2005 | 07:13 PM
Rcp's Avatar
Rcp
i don't like the drop either.. i have those sets on my car with stock struts..
Old Dec 1, 2005 | 07:15 PM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: Anyone running on Eibach Sportlines.... (argetni aruca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by argetni aruca &raquo;</TD></TR><TR><TD CLASS="quote">why do every eibach springs make the front look higher? its hella ugly man.
prokit
and according to that pic: sportline:
U think they would do some research before they developed those springs...
No one likes a speed boat looking car. At leat put a warning signs: "Will make ur car look like speed boat if installed" and ride like one also. Do not try to turn if ur going over 30mph cuz ur will rock the car like ur in a boat. causing over and understeering</TD></TR></TABLE>
How a car looks and how it handdles are not the same. The front is NOT "higher" either. The fact that there is more 'gap' between the wheel and the wheel well in the front then compared to the rear is simply a matter of how the car was designed - so no matter what springs you put on your car - it will look like that - UNLESS, you drop the car SO low that the tops of the wheels are tucked within the wheel wells. Also, Did you ever notice that that bottom of the car is level & parallel with the ground! That's how its supposed to be!
Old Dec 1, 2005 | 07:17 PM
MansuDC2's Avatar
Default Re: (dc2nick)
That pic is with 15" would it look different with 16" rims and tires. Here is a pic of my car and height it is right now, would it look like this if I use the sportlines?
dc2nick's Avatar
Default Re: Anyone running on Eibach Sportlines.... (Tim2179)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tim2179 &raquo;</TD></TR><TR><TD CLASS="quote">
How a car looks and how it handdles are not the same. The front is NOT "higher" either. The fact that there is more 'gap' between the wheel and the wheel well in the front then compared to the rear is simply a matter of how the car was designed - so no matter what springs you put on your car - it will look like that - UNLESS, you drop the car SO low that the tops of the wheels are tucked within the wheel wells. Also, Did you ever notice that that bottom of the car is level & parallel with the ground! That's how its supposed to be! </TD></TR></TABLE>
Thank you!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MansuDC2 &raquo;</TD></TR><TR><TD CLASS="quote">That pic is with 15" would it look different with 16" rims and tires. Here is a pic of my car and height it is right now, would it look like this if I use the sportlines?
no... it should look EXACTLY like mine, only the tire sidewalls will be smaller and the rims will be bigger. but the total size of wheel and tire will be exactly the same as mine.
Old Dec 1, 2005 | 07:21 PM
MansuDC2's Avatar
Default Re: (MansuDC2)
I used to have a set of sportlines on my 91 accord and yeah it looked the same way but the front wheel well is cut bigger, but the car is even.
Old Dec 1, 2005 | 07:22 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2nick &raquo;</TD></TR><TR><TD CLASS="quote">they do make the front look a little bit higher.
dont judge them if you dont know. I take turns at rediculous speeds and the back end wont budge. </TD></TR></TABLE>
way to hate... and isn't the pro kit meant for dragging?.. the eibachs have incredibly luxery feel on the roads.. who cares about ur thought and opinion on these
Old Dec 1, 2005 | 07:23 PM
dc2nick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MansuDC2 &raquo;</TD></TR><TR><TD CLASS="quote">I used to have a set of sportlines on my 91 accord and yeah it looked the same way but the front wheel well is cut bigger, but the car is even.</TD></TR></TABLE>
the car is lever w/ the ground because all the springs are cut for the same size drop all around.
Old Dec 1, 2005 | 07:24 PM
dc2nick's Avatar
Default Re: (ohsnapzafingcu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohsnapzafingcu &raquo;</TD></TR><TR><TD CLASS="quote">
way to hate... and isn't the pro kit meant for dragging?.. the eibachs have incredibly luxery feel on the roads.. who cares about ur thought and opinion on these</TD></TR></TABLE>
... what??
I dont have the pro kit. I never said anything about it.
I have the sportlines and im backing them up completly. I think theyre awesome.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by argetni aruca &raquo;</TD></TR><TR><TD CLASS="quote">again, learn to read. i said they make the front "LOOK"higher. people are always defending eibach about how the front is not higher, its the actual fender gap.
i say, who cares. eibach springs are the ONLY spring that does this.
i thought it was just the pro kit because of the even .75 drop all around. But i guess their sportlines sucks too. haha.
dont get mad at me cuz ur drops looks off.
im not getting mad at anyone. I love these springs. They are great. I kno it looks like the front is higher, but it is just the fender. The car is level
Old Dec 1, 2005 | 08:27 PM
Vi3tboy's Avatar
i love my coilovers. when i was in the market for suspension i thought about sportlines. but after seeing how many ppl had the boat effect to it im glad i went with coilovers. if anything go with the hr sport springs. they have a lower drop in the front to make the gap look even.
Old Dec 1, 2005 | 08:31 PM
dc2nick's Avatar
Default Re: (Vi3tboy)
I love the way they handle, but im going w/ a completly new setup. Im basically rebuilding the entire car.
Old Dec 1, 2005 | 10:53 PM
MansuDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vi3tboy &raquo;</TD></TR><TR><TD CLASS="quote">i love my coilovers. when i was in the market for suspension i thought about sportlines. but after seeing how many ppl had the boat effect to it im glad i went with coilovers. if anything go with the hr sport springs. they have a lower drop in the front to make the gap look even.</TD></TR></TABLE>
I've heard that H&R's sag over time though is that a fact or just some rumor?
Old Dec 2, 2005 | 12:29 AM
IntegraDriver's Avatar
how about just cutting the springs? cut off like a coil or 2 on the eibach i know its not recommended but how much will it affect the ride and handling? i might do it to mine cause i dont like the way how the gap in the front is higher
Old Dec 2, 2005 | 04:25 AM
dc2nick's Avatar
Default Re: (IntegraDriver)
bad idea.... not only will you hurt handeling, you chance hurting the stregnth of the springs....
Old Dec 2, 2005 | 10:05 AM
Vi3tboy's Avatar
yes you do not want to cut your springs. but the hr sagging problem. ive heard of a couple times. but i have 4-5 friends running the sports and race with no problem from hr.
Old Dec 2, 2005 | 10:37 AM
gogogomoveit's Avatar
I've heard that H&R's sag over time though is that a fact or just some rumor?</TD></TR></TABLE>
I have my H&R OE sport springs for 2 years now. It starts off slightly high in the back (0.75in drop) , but over the years it sagged a slight bit and right now it is about 1 inch drop in the back. The front has been always about 0.75 inch drop.
Old Dec 2, 2005 | 11:48 AM
gargsta's Avatar
Default Re: (gogogomoveit)
prokits are a 1.3in drop all around
with a set of tokico blues it creates a very luxirious feel (smooth like stock) but still stiff enough to take hard turns and a drop which is perfect for daily driving
couldnt be happier w/my decisiion to get these
Old Dec 2, 2005 | 09:25 PM
MansuDC2's Avatar
Default Re: (gargsta)
Does H&R sport springs make the car have that look where the front looks high and the rear looks lower? Which drops lower Eibach sportlines or H&R sport? I know H&R is like a 1.75" drop and aEibachs 1.8"? Well reason i'm asking... if you look at my post up there where i posted a pic of my car on 16" slips would it look dropped like that if I switch to H&R sport or Eibach Sportline Springs? I like the stiffness of coilover sleeves but I like set height springs because they're less stiff but gives you that balanced ride of stiffness and comfortable daily driving ride.
Old Dec 2, 2005 | 10:36 PM
Ls-Turbo's Avatar
Old Dec 2, 2005 | 11:28 PM
Default Re: (Ls-Turbo)
sorry to jack your thread but how bad will it hurt to cut the springs i want to cut my eibach sportlines in the front a bit.. only going to be used for daily driving not taking turns or anything like that so will it harm my handling that bad??
Old Dec 2, 2005 | 11:45 PM
Ls-Turbo's Avatar
bad idea.. for a cheap person.. dont do it spend some money n do it right..
Old Dec 3, 2005 | 10:06 AM
MansuDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls-Turbo &raquo;</TD></TR><TR><TD CLASS="quote">
Is this pics of your ride with H&R sport or Eibach sportlines? Looks pretty even.
jruiz094
Suspension & Brakes
Dec 29, 2012 10:04 PM
gary95H22Accord
Jul 23, 2012 06:01 AM
messeduprex
14
Apr 10, 2007 11:06 AM
thehatchninja
Sep 25, 2003 11:20 AM
PetroGuyX
Jun 15, 2003 03:20 PM
