throttle / clutch cable for b16a?
Old Dec 1, 2005 | 01:47 PM
integra95gsr's Avatar
Default throttle / clutch cable for b16a?
i guess i need a new throttle and clutch cable for my b16 swap. where can i get them, does anyone have them forsale? also will i need anything else, brakets or anyhting like that?
Old Dec 1, 2005 | 01:51 PM
EL Vap133's Avatar
Default Re: throttle / clutch cable for b16a? (integra95gsr)
http://www.hondaautomotiveparts.com
Or your local Honda dealer.
Old Dec 1, 2005 | 01:54 PM
CRXBart's Avatar
Default Re: throttle / clutch cable for b16a? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.hondaautomotiveparts.com
Or your local Honda dealer. </TD></TR></TABLE>
or a junkyard. I don't know why you need a clutch cable though???? I always used stockers. As for the throttle you need a unit from an Si, I have an extra in my garage, but I like to hold on to stuff like that, never know when you might buy another car and need to do a swap.
Old Dec 1, 2005 | 07:14 PM
the car is an ef CIVIC SI...can i just use stock ones?
Old Dec 1, 2005 | 08:00 PM
crxnj's Avatar
The stock clutch cable works ,But you wont have much adjustment with it as it is a little short,,and the stock throttle cable works but you have to run it a diffferent way..Its best just to get the 90-93 integra cables..THey work best
Old Dec 1, 2005 | 08:03 PM
i cant find the integra cables anywhere. the dealer wants like $60 each.
how do you have to run the throttle cable?
Old Dec 1, 2005 | 08:09 PM
crxnj's Avatar
Default Re: (integra95gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra95gsr &raquo;</TD></TR><TR><TD CLASS="quote">i cant find the integra cables anywhere. the dealer wants like $60 each.
how do you have to run the throttle cable?</TD></TR></TABLE>
You run it behind the motor,and it will have a bit more slack..
Its best to get the 90-93 integra one though..No junkyards by you?
Old Dec 1, 2005 | 08:10 PM
CRXBart's Avatar
If you have an Si cable just use it. It will work fine. You really don't ever have to adjust a throttle cable anyway. I forgot the teg cables were different. I beleive the one in my garage is off of a teg actually.
Old Dec 1, 2005 | 08:12 PM
you say you think you have an integra throttle cable?
-- can you use the stock SI cable? if so how to you make it work?..
Old Dec 1, 2005 | 08:20 PM
EL Vap133's Avatar
You sure? I got one from Acura for $38.
http://www.acuraautomotiveparts.org.
Old Dec 1, 2005 | 08:48 PM
how do you make the stock SI one work
Old Dec 2, 2005 | 06:30 AM
bump
Old Dec 2, 2005 | 12:58 PM
g-ride-si's Avatar
stock clutch cable is fine, i havent been able to use a throttle cable on any swaps though, but ive never tried. i always use a teg cable since i can find like 5 in a junkyard in a day. as for the clutch cable just cut a little of the sheath back on the stock si one, so you have adjustment.
Old Dec 2, 2005 | 02:39 PM
90civSi's Avatar
bump
Old Dec 4, 2005 | 03:35 PM
g-ride-si's Avatar
Default Re: (90civSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civSi &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
bump for what the question was answered
Old Dec 6, 2005 | 01:12 PM
Default Re: (g-ride-si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g-ride-si &raquo;</TD></TR><TR><TD CLASS="quote">stock clutch cable is fine, i havent been able to use a throttle cable on any swaps though, but ive never tried. i always use a teg cable since i can find like 5 in a junkyard in a day. as for the clutch cable just cut a little of the sheath back on the stock si one, so you have adjustment.</TD></TR></TABLE>
so yeah, i dont understand what you mean by cut the sheath back, someone, anyone some input!
Old Dec 6, 2005 | 01:29 PM
i cut some down around the bottom and all it was under the 'sheath' was metal tubeing. so i suppose i did it wrong?
Old Dec 6, 2005 | 02:14 PM
g-ride-si's Avatar
no thats right, just cut/unravel about a 1/2 to 1 inch of that metal tubing then slide the adjuster up over the part you cut.
Old Dec 6, 2005 | 03:46 PM
how much do you suggest to cut back?
Old Dec 6, 2005 | 04:59 PM
CarAudioPro's Avatar
to do a b16 swap in a ef you need, axles, shift linkage, b-series mounts, ecu, you have to run vtec and knock sensor wires, your clutch cable should work, if not use a 90-93 tegy one, and if you have a dx you need to use si throttle cable, or one form a 90-93 tegy.
Old Dec 6, 2005 | 07:02 PM
Default Re: throttle / clutch cable for b16a? (CarAudioPro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarAudioPro &raquo;</TD></TR><TR><TD CLASS="quote">to do a b16 swap in a ef you need, axles, shift linkage, b-series mounts, ecu, you have to run vtec and knock sensor wires, your clutch cable should work, if not use a 90-93 tegy one, and if you have a dx you need to use si throttle cable, or one form a 90-93 tegy.</TD></TR></TABLE>
how does this have anything to do with me cutting the sheath for the clutch cable...?
Old Dec 6, 2005 | 08:10 PM
g-ride-si's Avatar
wow, good call.
just cut a bout a 1/2 inch to start, see if it works.
Old Dec 6, 2005 | 08:25 PM
lol "wow, good call.".. heh
alrighty ill see what i can mess up next and them ask more questions.. heh thanks~
Old Dec 7, 2005 | 03:10 PM
ok so i got the clutch cable on.blah blah blah.. but when u push the clutch pedal in, it doesnt come back... its like there is no spring. sooo does this have anything to do with not having any tranny fluid in it yet?
Old Dec 7, 2005 | 07:06 PM
g-ride-si's Avatar
you probably dont have it tight enough
pull the arm on the tranny(where the cable goes) up as high as you can, then tighten the adjuster nut down onto it until the pedal feels right.
