Bad coilover installation
Old Mar 13, 2002 | 08:02 PM
sbrocks1's Avatar
Default Bad coilover installation
Went to go get my coilovers installed and the guy ended up ripping the head of my bolt that holds the lower control arms together. I've heard this is a problem on older cars do to rust and that it is a pain in the ***. Just wondering if anybody had a good solution or expierence with this problem.
Old Mar 13, 2002 | 08:07 PM
Jared's Avatar
Default Re: Bad coilover installation (sbrocks1)
you can either drill it out or torch it out.
Old Mar 14, 2002 | 12:10 AM
carsaregood's Avatar
I'd drill it out, using an extractor kit or some equivalent... you can find these at Sears. When I bought mine, it came with really bad drill bits, and I immediately broke 2. So I bought a few cobalt bits, those worked way better.
The way the extractor works is: you drill a hole inside the bolt. Then you put in the extractor bit, and it will grab the bolt as you spin it out.
Old Mar 14, 2002 | 04:24 PM
sbrocks1's Avatar
Default Re: Bad coilover installation (carsaregood)
But what if the bolt is still rusted in, how are you suppose to pull it out?
Leb_CRX
Jul 30, 2020 03:28 AM
MakeshiftJPN
May 11, 2012 03:03 AM
danrocheleau
May 18, 2010 05:15 PM
vteck1ck
14
Nov 14, 2008 08:55 PM
Eg253
Suspension & Brakes
30
Jun 24, 2006 05:10 AM
