spoon Axleback question
Old Dec 1, 2005 | 12:46 PM
typeR564's Avatar
Default spoon Axleback question
im looking into getting a spoon Axleback for my itr. i was wondering if Axlebacks from civics works on a itr or i have to get an itr one? thanks
Old Dec 1, 2005 | 12:53 PM
98 Spec R's Avatar
Default Re: spoon Axleback question (typeR564)
I know that the civic hatchback exhaust tips are shorter than integras. I am not sure about the coupe though. I would just buy the one that is made for your ITR.
Old Dec 1, 2005 | 01:07 PM
typeR564's Avatar
Default Re: spoon Axleback question (98 Spec R)
arite thats all i wanted to know. thanks
Old Dec 1, 2005 | 01:11 PM
Stein's Avatar
Civic Spoon axlebacks will not work on DC2s.
Old Dec 1, 2005 | 06:58 PM
mugenracer's Avatar
They may not work but they will fit. I know of a 96spec ITR that arrived here in ireland with a spoon street exhaust from a civic bolted to it. My broter had a EJ2 coupe and my OE 96spec axle back bolted on to it no problem except that it was about an inch or two short of clearing the underside of the bumper
Old Dec 2, 2005 | 07:37 AM
RedR's Avatar
Default Re: (mugenracer)
it will fit though its a bit longer
Old Dec 2, 2005 | 11:05 AM
typeR564's Avatar
what about a dc5 one on a dc2?
Old Dec 2, 2005 | 11:18 AM
Circuit Star-29's Avatar
Thats what I was planning on doing for this year but you'll need to get Dc2 piping upto the canister.
Old Dec 2, 2005 | 11:21 AM
1GreyTeg's Avatar
Default Re: spoon Axleback question (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">Thats what I was planning on doing for this year but you'll need to get Dc2 piping upto the canister.</TD></TR></TABLE>
Why would you want to do that? Isn't the stock DC5 piping mandrel bent and of larger diameter?
Old Dec 2, 2005 | 11:24 AM
typeR564's Avatar
so will the dc5 one work or not?
Old Dec 2, 2005 | 11:29 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeR564 &raquo;</TD></TR><TR><TD CLASS="quote">so will the dc5 one work or not?</TD></TR></TABLE>
I'm guessing No, it's Not a direct fit/bolt up.
But it looks like noone knows for certain here and I can't say I blame them.
Maybe try the RSX forum to see if anyone there knows.
Silly question but why not just get an exhaust that's already made for your car? I mean there's already a ton out there readily available and you won't have to go hack job it up or deal with wondering online what hybrid setup "might" fit.
Old Dec 2, 2005 | 11:36 AM
98 Spec R's Avatar
The DC5 R exhaust is very different. The exhaust bends differently due to the cat connection and header being in the rear of the engine bay as opposed to in the front on a DC2. Major modification would have to be preformed to get this to work.
typeR564's Avatar
Default Re: spoon Axleback question (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">I'm guessing No, it's Not a direct fit/bolt up.
Silly question but why not just get an exhaust that's already made for your car? I mean there's already a ton out there readily available and you won't have to go hack job it up or deal with wondering online what hybrid setup "might" fit.</TD></TR></TABLE>
well im asking because i found a good deal on the spoon n1 for a dc5...
Old Dec 2, 2005 | 11:38 AM
Sorry, I didn't clarify. I would use this old Tsudo 2.5 cat back and weld the can on. I just need to find a DC5 Spoom N1 can. I saw one around a few months back.
No, you cannot put a DC5 Axle back on a DC2. I tried. Routing is all wrong.
Old Dec 2, 2005 | 11:41 AM
98 Spec R's Avatar
well im asking because i found a good deal on the spoon n1 for a dc5...</TD></TR></TABLE>
You have very nice car, an ITR, why dont you spend a little more money and get the correct one? You cant be a cheap *** with your ITR!
Old Dec 2, 2005 | 11:43 AM
typeR564's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R &raquo;</TD></TR><TR><TD CLASS="quote">You have very nice car, an ITR, why dont you spend a little more money and get the correct one? You cant be a cheap *** with your ITR! </TD></TR></TABLE>
good point
but im talkin about the axle back not the cat bak
Old Dec 2, 2005 | 11:46 AM
good point
but im talkin about the axle back not the cat bak</TD></TR></TABLE>
I pm'd you.....
Old Dec 2, 2005 | 04:55 PM
usdmegek's Avatar
i tried a dc5 exhaust on my itr and all the bends seem to route the right way. the only thing is it's a little short and the flange needs to be turned a bit. nothing any local muffler shop cant do. hope that helps
Old Dec 2, 2005 | 08:47 PM
Default Re: spoon Axleback question (usdmegek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdmegek &raquo;</TD></TR><TR><TD CLASS="quote">i tried a dc5 exhaust on my itr and all the bends seem to route the right way. the only thing is it's a little short and the flange needs to be turned a bit. nothing any local muffler shop cant do. hope that helps </TD></TR></TABLE>
Not even close dood....
Spoon ITR
Jul 6, 2007 04:48 PM
typeR564
Dec 2, 2005 08:00 PM
HondaLaw
Jun 25, 2004 03:17 PM
swlabhot
Dec 18, 2003 12:03 AM
B2FiNiTY
Jan 7, 2002 11:41 AM
