Changed Main Relay 91 CRX will not start
Old Dec 1, 2005 | 12:12 PM
fracas's Avatar
Default Changed Main Relay 91 CRX will not start
So I swap my Blown motor out of my 91 crx and the car wont start now. So I did a search and found out that I need to check the main relay. Well I Bought a New relay. Installed it today. And Now I have no sound coming from the fuel pump or Fuel Pressure. Is there any other Fuse's I need to look for?
Old Dec 1, 2005 | 12:16 PM
jlicrx's Avatar
Default Re: Changed Main Relay 91 CRX will not start (fracas)
do you have the ground wire at the thermostat housing connected?
Old Dec 1, 2005 | 12:33 PM
fracas's Avatar
Yes. And the Tranny is grounded as well.
Old Dec 1, 2005 | 11:21 PM
90CRXB17TURBO's Avatar
Default Re: (fracas)
what you can do is.. check the fuel pump at self to see if it pumps, also you can check the fuse.. see if anything there is blow. common one is the alternate solenoid. mostly likely if you dont hear the fuel pump start then your car will not start.. so solve that problem first.
Old Dec 2, 2005 | 06:22 AM
fracas's Avatar
/\ Boy you were alot of help!! Ive checked everything. Still No power to the fuel pump!
Old Dec 2, 2005 | 06:49 AM
crx_88_si's Avatar
did u reconnect the battery?
does the Check Engine Light come on when you first turn the key to ON ?
Old Dec 2, 2005 | 06:54 AM
fracas's Avatar
Ok that battery is dead. but I jump it off every time . Now all the grounds are Connected. The Check engine light comes on as I turn the key. Then you will hear the Beeping noise untill the key is turned forward. Now i unhooked the fuel line and turned the key forward and there is NO fuel Pressure.
Old Dec 2, 2005 | 07:10 AM
crx_88_si's Avatar
ok.. now you have to give the pump 12v directly from the battery to see if it works. if it does then there is something wrong w/ the wiring between the main relay and the fuel pump.
Old Dec 2, 2005 | 07:17 AM
fracas's Avatar
The car was running 2 months ago.
And do I have to drop the tank to check the Pump?
Old Dec 2, 2005 | 07:19 AM
b18_crx's Avatar
U CANT HEAR the fuel pump priming?
Old Dec 2, 2005 | 07:22 AM
fracas's Avatar
Fuel Pump makes No noise. But Like I said . Before the motor Blew the car was running.
Old Dec 2, 2005 | 07:26 AM
b18_crx's Avatar
MY FIRST crx did the same thing and it was the main relay.....replaced main relay and then blew like 3 fuses.....check fuses!
Old Dec 2, 2005 | 07:27 AM
fracas's Avatar
Checked all fues's All are good.
Old Dec 2, 2005 | 07:28 AM
BiG Chris's Avatar
we did a swap on my friends crx and the same thing happend, i made a jumper harness for him instead of the main relay and now the car runs just fine. PM me if you want to know how to make one.
Old Dec 2, 2005 | 10:55 AM
fracas's Avatar
bump
Old Dec 2, 2005 | 01:09 PM
fracas's Avatar
anyone?
Old Dec 3, 2005 | 05:41 AM
fracas's Avatar
WEll'?
Old Dec 3, 2005 | 05:52 AM
b18_crx's Avatar
if i get my car running today ill be more than glad too lend a hand tonite or tommorow!
Old Dec 3, 2005 | 06:36 AM
fracas's Avatar
This problem is getting on my Nerves.
Modified by fracas at 6:40 PM 12/7/2005
Old Dec 7, 2005 | 03:40 PM
fracas's Avatar
ttt
Old Dec 7, 2005 | 03:45 PM
b18_crx's Avatar
any updates....i got my car running
Old Dec 7, 2005 | 06:17 PM
fracas's Avatar
Still not running. And Now there is snow everywhere So Im going to wait till it clears up!!
Old Dec 10, 2005 | 07:34 AM
fracas's Avatar
bump
Old Dec 10, 2005 | 10:30 AM
fracas's Avatar
ttt
Old Dec 10, 2005 | 03:27 PM
fracas's Avatar
anyone?? Im still not getting Power to the fuel pump
